Gear Question
Old May 5, 2001 | 01:28 AM
Fadex's Avatar
Post Gear Question
I talked to a local Mustang shop today and they recommended changing the rear gears out to something like 4.11's. What kind of changes can I expect will this new gear ratio. Fuel mileage, Times, ect. Any info or advice would be greatly appreciated.
Old May 28, 2001 | 08:42 PM
dvldog458's Avatar
Post
Fadex,
What kind of truck do you have?What gears are in it?
What size engine do you have?
Do you have an OD trans?
What size tires do you have now?
Jerry D
http://hometown.aol.com/dvldog458/myhomepage/auto.html
Old May 28, 2001 | 09:10 PM
Fadex's Avatar
Talking
My truck is a '96 F-150
3.55 LS
4r70W overdrive
5.0L
Stock Firestone Firehawks
'96 F-150 302
Hedman Hedders, Catco Cat., Gibson Super Truck, K&N F.I.P.K.
Old May 29, 2001 | 12:55 AM
dvldog458's Avatar
Post
Fadex,
I take that you are looking for better 1/4 mile times.
Since you have an overdrive trans you could go with taller (numerically higher) gears.
I would recommend 4.10's
You will definitely notice the difference in your 0-60 mph times.
As far as gas/mileage it's gonna get pretty crappy.
That 302 has alot of potential,just give it a chance.
I hope this helps.
Jerry D.
Old May 30, 2001 | 01:26 AM
Fadex's Avatar
Red face
Well, I have had to put the mods on hold for right now. I have a clicking sound coming from the right (passenger side) of the engine. I think (hope) it is a small exhaust leak from the header gasket area. Sounds like a sewing machine on steroids, but no loss of power and gas mileage is improving if anything. Any other ideas?
'96 F-150 302
Old Jun 1, 2001 | 05:36 PM
dvldog458's Avatar
Post
Yes,i think it might be an emissions sensor.I can't think of the proper name right now.If your standing in front of your truck looking at your throttle body it should be to the left of it (witin 6-8 inches)it looks just like a "C" battery just alittle smaller w/ an electric connection.I'm sure someone here knows the proper name for this part.
I hope this helps!
Jerry D
Old Jun 1, 2001 | 06:23 PM
Fadex's Avatar
Post
Thanks for the idea! I'll go check my chiltons and see if I can match it up.
'96 F-150 302
Old Jun 1, 2001 | 11:21 PM
Fadex's Avatar
Question
I looked to the left of the throttle bodies and the only thing I see is the EVP senson on the EGR valve. Neither of them look like a battery. Maybe I'm looking in the wrong place. Can you give me better directions of where to look. This noise is driving me crazy!!!!!
'96 F-150 302
Old Jun 3, 2001 | 10:08 PM
dvldog458's Avatar
Post
That sensor is right in that area.Damn i wish i knew the proper name.I tried looking in my chiltons manual for my vehicle.No luck!
Ok,lets break this down.Your sure the clicking is coming from pass side of engine?
Is it making the sound at a certain RPM or just at idle?Is it loud like a valve tap?
We'll figure this out.
Jerry D
Old Jun 4, 2001 | 12:40 AM
Fadex's Avatar
Post
Thanks for your help. I really appreciate it.
I am positive it is coming from the passenger side. I can hear it from idle all the way up as long as my foot is pressing the gas pedal or the engine is under a load (like going up a hill) and it does sound like a valve tap or click. But on the plus side I think my mileage has went up quite a bit. 80 miles on 1/4 tank. It almost worries me that my mileage is that good. Any help is greatly appreciated. Thanks!!
'96 F-150 302
Old Jun 5, 2001 | 06:44 AM
Scratchen4Traction's Avatar
Wink
By chance are you thinking of the O2 sensor.
My trucks not home right now so I can't check.
Old Jun 5, 2001 | 01:21 PM
dvldog458's Avatar
Post
No the component is up by the throttle body.It has a wire plug and a vacume fitting.
Fadex,
Have you changed the exhaust in any way recently?This could be the problem.
[This message has been edited by dvldog458 (edited 06-05-2001).]
Old Jun 6, 2001 | 12:32 AM
Fadex's Avatar
Post
The hedders were installed and the cats replaced about three months ago.
Is the part you are talking about the bypass valve on the throttle bodies that allows the engine to idle?
'96 F-150 302
Old Jun 23, 2001 | 09:39 AM
dvldog458's Avatar
Post
no it's on the opposite side of the air byass valve.
I'm thinking it's a exhaust leak header/ collector gasket.
Let us know what you find.
Old Jun 24, 2001 | 01:56 PM
Fadex's Avatar
Post
I finally found the problem.. I thought I had blew out the header gasket. Wrong..
The connection between the header and Y-pipe on the passenger side had come loose and the gasket was shreadded. New gasket. Tightened the bolts and problem solved..
'96 F-150 302
