High, sporatic idle
Old 09-13-2008, 12:52 AM
89rusty's Avatar
High, sporatic idle
Hi guys, I have an 89 F150, 4.9, 4 speed, 4x4. The truck has a bit of an idle issue, when I first start it, it will jump to 2000 rpm and just sit there for I'd say about 3 seconds. Then it will idle down to about 1100-1200, stay there, but sometimes jump down to normal idle speed for a second.
I'm thinking maybe the IAC? One of my friends said check the thermostat, but that didnt really make sense to me.
THANKS
Andrew
(just wanted to use that, I mean how awesome is a dancing banana?)
Old 09-13-2008, 11:54 AM
PURExCOUNTRY's Avatar
its def your IAC or you have a vacuum leak somewhere.
your thermostat in a 89 will have nothing to will the idle. only very late obd2 motors have an ECT(engine coolant temp) sensor that is an input for the PCM
Old 09-13-2008, 04:09 PM
Matts ford's Avatar
most likely iac or vaccum leak. spray carb cleaner around the plenum gasket and throttle body gasket and such and see if the idle changes a little bit. if not then its the iac and i'd recommend you clean the throttle body when you do it.
Old 09-13-2008, 04:30 PM
wow wow wow...dont ever clean it with brake cleaner or anything like that. you will ruin it
Old 09-13-2008, 04:58 PM
Matts ford's Avatar
who said anything about brake cleaner? i said use carb cleaner to see if theres a vacuum leak around one of the gaskets. though i guess i should have said clean the throttle body with throttle body and air intake cleaner and a old tooth brush.
Old 09-15-2008, 09:25 AM
PKRWUD's Avatar
Who told you that?!?!?
Old 09-15-2008, 12:27 PM
im talking about 2003 and later. all obd 3 vechicles use them as well
Old 09-15-2008, 01:05 PM
PKRWUD's Avatar
Both your '96 OBDII F-150 and my '95 OBDI F-150 have ECT's, and both of our ECM's rely on the input from them.
Old 09-15-2008, 10:28 PM
GTRider245's Avatar
Yup! You got some wrong info there bud.
Old 09-19-2008, 06:25 AM
ymeski's Avatar
Try cleaning & relubing throttle linkage /check for potential binds/movement restriction. Idle speeds & durations at start will vary with condition of engine in relation to the external conditions each time.
Quick Reply: High, sporatic idle
