Is my water pump going?
Old 05-15-2007, 11:57 AM
Scraper's Avatar
I have a 1995 F-150 5.0L 2WD with 183,000 miles and the original water pump. My driveway has a very slight incline. When I pull in head-first (so the front of the truck is uphill), everything is fine. If I back-in (so the front is slightly downhill), I notice a little puddle of coolant the next day. (When the truck is parked level, I haven't seen any coolant.) It seems to be coming from the water pump area. Could it be leaking past the shaft? Could it be the gasket?
I am assuming that it is time to replace the pump. Any thoughts/tips/comments/advice will be greatly appreciated.
Thanks,
Scraper
Old 05-15-2007, 01:03 PM
taisa899's Avatar
climb underneath it after you park to see if you can find the leak
Old 05-15-2007, 04:47 PM
Bruce R Leech's Avatar
that water could be coming frome 50 different places. find the leek before you buy parts.
Bruce
Old 05-16-2007, 12:00 AM
Steve83's Avatar
Look before you leak.
Old 05-16-2007, 06:59 PM
RaWarrior's Avatar
Dry everything off with a rag, and then "back in" or whatever seems to cause the leak and just look for the wet spot. If you have trouble locating it, buy a can of that white foot power spray. Clean off all wetness and paint every possible place it could leak from with the powder. Hoses(particularly connection), around the water pump, all connections to/from radiator, everything. Do the "back in" again and see where the white power is no longer white.
Remember- Ford trucks don't leak, they mark their territory.
Old 05-16-2007, 09:56 PM
Steve83's Avatar
Originally Posted by RaWarrior
...white power...
Typo, or Freudian slip?
Old 05-17-2007, 12:04 AM
cavinandpavin's Avatar
change it anyway. my 88 had the original pump on it at 178K or so ...till i spun 3 mains. the pump would hardly turn it was completely full of crap, i dont see how it moved any water at all, but it never leaked.
Old 05-24-2007, 06:57 AM
keith97xlt's Avatar
grab the fan and shake it to see if you have any play?? when a bearing goes it has that grinding noise. a 183k its on borrowed time anyway.
Quick Reply: Is my water pump going?
