Will these wheels and tires fit my 92?
Old Jul 15, 2006 | 01:34 PM
TheGrayt1's Avatar
A set of 15x10 in Eagle wheels for 5 lug Ford fits F150's, Expeditions w/ 33in Maxis tires
That is how he has them listed. Will the wheels bolt up, and will the tires fit under the fenders wo rubbing?
My f150 is a 92 ext 2wd 4.9l. Also how bad would the ride and gas mileage be as compared to now?
I can get them for $150 and the tires are in great shape.
Old Jul 15, 2006 | 03:22 PM
81F150's Avatar
I am gonna guess that they would rub with your truck being a 2 wd. The wheels should fit and bolt up ok. For 150 dollars, if you got it to spare you cant go wrong by getting them, could always sell the 33's and put 31's on. They probably would look better on your 2wd in my opinion. If you lift your truck your probably safe with the 33's. Your gas milage will go down. Good luck!
Old Jul 15, 2006 | 03:46 PM
adrianspeeder's Avatar
50's till 96 half tons are 5lug 5.5" pattern
97-03 half tons are 5lug 135mm pattern
Because you say an expy that sounds like a metric wheel lug pattern
33's will fit 92-96 if you space out the front bumper with some washers.
Adrianspeeder
Old Jul 15, 2006 | 10:03 PM
Mitch556's Avatar
Hey I just wanted to know while you guys were on this topic is there a difference in clearence between the 4X4 and the 2wd.
Old Jul 18, 2006 | 01:29 AM
GTRider245's Avatar
Yes. One sits higher than the other.
Old Jul 23, 2006 | 01:44 AM
TheGrayt1's Avatar
So I never got a definite answer, will these bolt up since it says it is for expeditions as well? will the tires rub?
I talked to the guy and he said the tires have nearly 60% tread left and hold air fine. the wheels are polished Eagles 15x10. I worked him down to $100. What do you think...
Old Jul 23, 2006 | 06:20 AM
StrangeRanger's Avatar
Ask him what the bolt pattern is or what year F150/Expy.
5 x 5.5 will fit; 5 x 135 will not.
96 down will fit; 97 up will not.
Old Jul 23, 2006 | 10:39 AM
I'm gonna bet no since expy is 97+ You need to ask what year.
Adrianspeeder
