Two questions on Haynes procedures for 1991 5.0 F150
According to Haynes, to remove the oil pan you have to first remove the upper intake manifold. Is it possible/reasonable to remove the pan without having to take off the intake manifold?
Again, according to Haynes, to remove the engine you have to first disconnect the AC lines and discharge the AC system -- is there any way to just unbolt the AC compressor and hang it out of the way without discharging the AC system?
Originally Posted by GTRider245
Correct. The gasket is fairly easy to do, unless its been there a while and you have to scrape off the old one, which may require taking the pan out.
