electric fan conversion
two questions - why not a pusher fan, instead of a puller? since there appears to be more room in front of the radiator than behind it, why not mount the fan there and have it blow through the radiator?
second - does the markVIII fan really pull 42amps? wow! how do you handle that load?
jg
jg
I'm not certain, but I would venture to guess that fan only draws that kind of current during initial start up. Most electric fans have a bigger spike in the draw during start up, but it's for milliseconds.
Puller fans are more efficient because they create a low pressure behind the blades, which is across the radiator in the case of a puller. A low pressure like this aids in cooling. Although very minimal, it's still there. A pusher fan on the front would create a high pressure in front of the blades. In the case of a pusher, this high pressure would be across the radiator and a high pressure creates heat. A pusher in front of the radiator would also block the surface area of the radiator, again decreasing cooling.
however, the 42 amps i read for the MarkVIII is running amps - the start up is even worse. a 42 amp load for an efan just doesn't sound right - if it's that bad, why switch? OTOH, the MarkVIII is supposed to be able to move a whole lot of air...
On my Lightning I used a Mark VIII fan with a Mad Enterprise's controller. It has 2 relays in parallel. My fan pulls around 50 amps for start and runs around 25-35 amps. The controller has 2 sensors. One for the radiator which you can adjust to suit your needs. The other can be used in the evaporator so your a/c stays cold.
