cv boots
Old Sep 22, 2009 | 10:20 PM
jjmegs's Avatar
cv boots
I have a 2001 f150 supercrew I was wondering if anybody has changed their CV boots on the front axles. Is this a big job!!!!
Old Sep 23, 2009 | 10:03 AM
mdhawkin's Avatar
Its not that bad, you have to pull the axle out the spindle/hub. In order to do that you have to disconnect your control arms etc. If you are not comfortable with it you may want to check around on finding someone to do it, its not that bad. I busted a boot once and took it to a 4x4 shop and they charged me $150 to replace both boots on that axle (a little high). Later I broke a CV joint and took it to another shop in town (my primary choice) and got cv joint/axle replaced, tires rotated and oil changed for $165. Cant beat that!!!
Old Sep 23, 2009 | 10:42 AM
It's generally best just replacing the whole axle with a rebuilt axle than trying to change the boots. If the boot is torn, you have already got contamination in the joint and its days are numbered anyway.
Old Sep 23, 2009 | 04:09 PM
JMC's Avatar
JMC
25 Year Member
You have to remove the half-shaft to fix the boot. The outer joint is non serviceable so if the outer is torn you have to remove the inner to get to it. Trying to get grease cleaned out of a joint that does not come apart is a real pita. It is easier to just buy a new half-shaft. Note: The bolts holding the joint to the axle are 12mm x 12point. The nut holding the half-shaft to the hub is a 35mm. If you remove the sway bar link the axle will come out without disconnecting the steering knuckle.
Old Sep 23, 2009 | 06:59 PM
willys5555's Avatar
my driver side boot has a cut in it somewhere because it is spraying grease under the truck. should i just replace this boot?
Old Sep 23, 2009 | 07:42 PM
DYNOTECH's Avatar
X2
Old Sep 24, 2009 | 02:00 AM
Old Sep 24, 2009 | 10:04 AM
willys5555's Avatar
I see. sounds like a big deal then.
Old Sep 24, 2009 | 10:51 PM
rus's Avatar
rus
I just did mine last weekend with handtools. All need to do is For drivers side. Jack up vehicle and put jackstand under frame.Turn wheel to left ,Disconnect both of the sway bar stabilizer bolts. Pull wheel cap,Remove 35mm nut,Remove the six 12 mm 12 point bolts,remove half shft. Reverse procedure. Took me just under an hour both sides. First time ever doing. Remember to use Loc Tite on the 12 mm bolts.
Doing the rear seal leak this weekend.
Rus
