vibration
Old Dec 16, 2007 | 01:34 PM
blkshdw's Avatar
vibration
i have an 05 150, the front end vibrates really bad when ingaged in 4x4, i have a 6" lift on it, what might be the problem.....?
Old Dec 16, 2007 | 03:39 PM
DYNOTECH's Avatar
Check the front driveshaft U joints.
Old Dec 16, 2007 | 05:29 PM
blkshdw's Avatar
i did and everything appears to be normal, is there anything specific that i should be looking for.... and now after driving for a bit, i have a clunking noise but only when off throttle, sounds like something is loose but i checked and rechecked everything and have no idea what it could be..... please help? LOL
Old Dec 17, 2007 | 09:17 AM
brianh178's Avatar
clunking
I had a similar problem with my 2002 f150. No vibration but had the clunking. The bolt that held the front diff. was gone and the clunking was the noise it made as it slapped the skid plate. Mine clunked on acceleration however.
-Brian
Old Dec 17, 2007 | 11:42 AM
blkshdw's Avatar
-Brian
cant be that cuz i dont have a skid plate, and i rechecked all of the nut and bolts last night, that and it didn't start until i put the driveshaft back in yesterday and before that while it was out i didn't have any noise at all
Old Dec 19, 2007 | 07:19 PM
DYNOTECH's Avatar
I just fixed a clunk noise that was driving me crazy trying to find in my 97 F150 4x4. The front sway bar link (passenger side)was broken. The bolt head actually popped off and to look at the link it appeared ok. Had to feel the top of link bolt to determine that the bolt head had come off allowing the bar to move around. Might want to check yours out I know several guys who have had the same problem. Tie rods and ball joints ok? Good luck
Old Dec 28, 2007 | 05:59 PM
gearmanx17's Avatar
This sounds more like a driveshaft angularity problem to me. Pinion is too high or too low?
D/S angularity needs to be set from 1 1/2 degress difference (maximum) in operating angle of u-joint A (front) vs. u-joint B (rear).
This can be easily checked with a liquid filled protractor. Vehicle should be on level ground & not jacked-up or elevated.
Old Jan 6, 2008 | 06:23 PM
blkshdw's Avatar
okay that osunds good, i will have to check that out, i now have also noticed another problem in terms of my gas milage, i used to get like 15.5 to 17.5 and now it feels like i am draggin a trailer with a car or 2 on it and i cant get my gas milage above 10-13, all stats provided by edge evo. any ideas
Old Jan 7, 2008 | 09:38 PM
blkshdw's Avatar
okay so i talked to a backyard mechanic friend of mine who says that my front dif. and vacuum lines are engaged but the trans case is not...... what do you guys think any ideas.....?
