replacing gray grill on 99 F150??
Are the grill's in the newer F150's interchangable?? I have a 99 XLT with the gray honeycomb grill, which I don't care for. Can I replace it with a 00/01 black grill easily?????
I'm fairly sure you can swap out the grill, I just gave my grey one to someone who switched it with his original. The trick is getting the old one out without breaking any retaining clips.
Jeff
Jeff
ive done it
I changed my horizontal bar grill on my 99 with a honycomb off of a 2001. I got it off of ebay for 45 with shipping and handling. it was some rv and truck customization company that sold it to me. they did a great job of rmoving the peice i got from them, all the tabs where whole and no scratches on the plastic.
I found one from Truck and Rv supply in Indiana. They want $35 plus $20 for s/h.....$55 total isn't bad. Is the Ford emblem in the center easy to change over?? How tricky are the mounting clips??
http://cgi.ebay.com/ebaymotors/aw-cg...item=593090833
not bad
the ford emblem on the front is easy to remove. there are two pins that line the emblem up and a third center stud that has a nut threaded onto it to keep the emblem in place. Getting the grilly out is a bit harder. I used two flat ended screwdrivers to spread the tabs apart. I started on the left and right sides because the have the smaller tabs. If you are not planning on reusing or resaleing you grill i would suggest breaking the tabs on it if it looks like the little arrow shaped tabs on the grill surround want to break. I had to break the two smallest lock tabs on my original grill to get it out. It just takes alittle patience. I did it in my parking spot at college in about an hour. thats includes pulling the headlights and grill surround off, changing the grill and putting it back together.
You will have to remove 2 or 4 plastic christmas tree rivets to get the grill sourround seperate from the front fenders. I used a wire sidecutter set of pliers and just cut them off. You can get replacement rivets from Lowes or any decent autostore.
