Tow Hooks on an '03 4x2?
Old Dec 18, 2010 | 12:36 PM
User 52622's Avatar
I can't find a definitive post that lets me know it'll work. Planning on adding a new front valence and fogs to my SCrew. The front of the frame has 2-3 holes on the side but none on the bottom. The tow hooks for that year all seem to mount to the bottom. Help... pics if possible!
Old Dec 22, 2010 | 11:47 AM
User 52622's Avatar
anybody?
Old Dec 25, 2010 | 12:30 AM
fairlaner's Avatar
Factory tow hooks can be mounted on a 2wd ... you need to drill two holes on the underside of each frame end to mount them. I know thejake1989 has done this ... he might have some pics in his gallery.
Old Dec 25, 2010 | 01:28 AM
thejake1989's Avatar
yup can be done you just need the factory stuff and to drill the holes
Keith
Old Dec 25, 2010 | 10:23 PM
fairlaner's Avatar
When you get your tow hooks, try to get the forged ones which came on the '97-'03+/- trucks ... the later year hooks will fit, but aren't as nice in my opinion.
Old Dec 26, 2010 | 10:53 AM
User 52622's Avatar
About what i figured... The next question is about the valance... i dont want the ends of the frame to be visable. Seen some pics where they do and some where the valance goes down far enough to cover... any tips?
Thanks!
Old Dec 26, 2010 | 01:48 PM
You can get a valance from a4x4 that has the cutouts needed for the hooks
Old Dec 26, 2010 | 07:00 PM
User 52622's Avatar
I just want to make sure I get the correct one... I've seen some that do not cover the end of the frame. Maybe OEM fits better? There is a 4x2 version... Maybe that's the wrong one? Are the frames different 4x2 vs 4x4?
Old Dec 27, 2010 | 10:20 AM
the oem ones are all interchangeable and just bolt to the metal part of the bumper and the4x4 valances will cover the frame and the fronts of the frames are also the same. mines a 98 that i put a 99+ bumper on with 4x4 valance and the tow hooks. look at my albums if you want some pics
Old Dec 27, 2010 | 10:39 AM
IIRC Raoul used some Chevy tow hooks that were slightly different design
Old Dec 27, 2010 | 11:49 PM
User 52622's Avatar
Thanks everyone... good info! Z7What has an awesome looking SCrew but if you look in his album there is a pic from the front where you can see the bottom of the frame and where the hook attaches. That's what i'm trying to avoid. I found a 4x4 valance w/fog and tow at a dealership here in San Diego for 130.00... picking it up tomorrow! Thanks again everyone!
Old Dec 28, 2010 | 02:54 AM
fairlaner's Avatar
Do you have a body lift on your truck? A body lift will raise the bumper/valance, exposing the ends of the frame.
Here's a pic of my stock 4X4 ... tow hooks hang down from the bottom of the frame and the ends of the frame are covered by the valance. One of our 4X2 '00 F-150's at work had tow hooks and the tow hook valance installed on it (materials guy was always getting stuck and needed some way to get pulled out ), and it looked just like my truck.
Old Dec 28, 2010 | 12:25 PM
User 52622's Avatar
no body lift on mine... After i posted I thought a little more about it and figured that a body lift would probably make the frame visible. Picking up my valance today... Just need to get the fogs mounted... found the switch on Amazon and the truck was prewired.
Thanks again!
