How to get my grill off
Old Oct 9, 2010 | 06:43 PM
mudkickin4x4's Avatar
How do i get the grill off my truck. I cant figure it out
its a 06 f150 with Bar style
Old Oct 9, 2010 | 06:52 PM
DarkShadowSTX's Avatar
There are 4 10mm bolts that hold the L-brackets from the grill to the hood. Remove those and the grill will be off your truck.
Old Oct 9, 2010 | 06:54 PM
i did that but i couldnt get it off. I used force but was afraid i was going to break it
Old Oct 9, 2010 | 07:00 PM
kingfish51's Avatar
There are 6 more 10mm bolts along the top edge of the grille for a total of 10 counting the L bracket bolts.
Old Oct 9, 2010 | 07:06 PM
ok well answer me this. I got a aftermarket grill for my truck and it has 3 threaded holes on top and 3 on bottom. Does this make sense?
Old Oct 9, 2010 | 09:20 PM
I stand corrected. I overlooked those 6 bolts, it's only been 2 years since I took my grill off to paint it.
Pics would help. Is it an overlay or something in which it might use those threaded holes to attach it to the grille?
Old Oct 10, 2010 | 12:30 AM
no i dont think cause it is a grill for 6" lights
Old Oct 10, 2010 | 07:03 AM
kingfish51's Avatar
Sounds like what you have is an insert. You will have to take the grill off the remove either by cutting or popping out the insert of the OE grill. I suggest though that you find instructions for the replacement grill. It should have all the info you need.
Old Oct 11, 2010 | 11:45 AM
i dont see how it would even fit right?
So i need to remove the grill and cut out holes for the lights?
It didnt come with instructions ha
Old Oct 11, 2010 | 12:04 PM
kingfish51's Avatar
Sorry, but without more info, no one here can help. Pics of the item would be nice, or a link to it.
Old Oct 11, 2010 | 12:12 PM
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old Oct 11, 2010 | 12:13 PM
i see it says insert now. But it still is confusing on how it would be done
Old Oct 11, 2010 | 12:24 PM
kingfish51's Avatar
It looks like the type that would require the cutting out or removal of the part of the OE grille, but cannot say for sure. Might want to try doing some searches on RDX billet grilles as that is who it says makes them. Without instructions, it is very tough to say what has to be done. That is definitely not a full replacement, which still leaves 3 options. Bolt over, remove insert, or cut out partial insert.
Old Oct 11, 2010 | 02:32 PM
So basically im gonna have to do some custom work ha
Old Oct 11, 2010 | 04:47 PM
johnnyd2723's Avatar
If you have to cut it use a dremmel. If you dont have one go get one.
