04-08 F150 nose on an 03-06 Expedition
the cervinis kit is a complete kit designed to change the f150, its not an expy nose and the limited is exactly like any regular F150.
If you are refering to doing either one of these to your 05 expy.. well er...
the first is pretty much just like you have now and the limited is like swapping any other F150 front end which was discussed.
If i really had the money to spend on a front end swap i would do the limited, it looks kick *** but it would have to be fully done meaning rims and ptm harley lower style-bars/rocker valances
Get an affordable set of used harleys and PTM them the tricoat white.
After all if your doing a limited front end swap you might as well do the tricoat pearl white
is it just me or is that front end pointing up more so than usual. I mean i know the truck is aired lower in the rear but even so it still looks like its pointing too far up. Like the driver side is higher and not aligned correctly or something.
Im disappointed, I have thought about doing that front end if anything ever happened to my truck and now i just dont know if i like it.
Now the 09+ front end that was posted on the street truck thread that is sick!
07 exp front end on a 04 f150.
I've thought about doing putting an 07-10 front end on my 05 F150. The fenders seem to line up. You would have to replace the bumper, valances, hood, and grill for your swap. You could keep the current 03-06 headlights and they should line up, unless its 07 and newer. No way am I expert but a guy I know that worked for a body shop said the fenders should be a perfect match. Once I get back from next deployment I do plan on putting the 07 front end on my truck. You can do it pretty cheap, I'm sure you could find the parts you need on ebay or at a nearby junk yard. But if you want new parts go to http://www.iautobodyparts.com
