replaced fender, not so straight forward
Finally got around to replacing my damaged fender. however it wasn't as straight forward as I was lead to believe. I discovered that the company used some sort of foam adhesive/insulation on the inside of the fender closest to the door. Had to rip out some of it so that I could get to one screw that was hidden underneath the foam. also there's a piece of sheet metal that was attached by this foam stuff as a spacer? between the old fender and the inner body panel. the antenna cable can't be disconnected at the body panel, you have to take off the glove box to disconnect the cable.the head light also has to be removed. The only thing left, is to replace the wheel well trim. at least the door isn't rubbing against the fender anymore.
