shaved door handles
Old May 14, 2001 | 06:58 PM
HOSRACN's Avatar
Post shaved door handles
has anybody here checked out the cost of shaved door handles? i haven't been able to get anybody to give an estimate. i would probably pull off the side emblems at the same time, cut down on paint costs if i were to do it later. any info will help.
Old May 14, 2001 | 11:43 PM
LoCo F150's Avatar
Talking
Almost any body person should be able to do the shaved door handles without any extra charge if your getting the door or truck painted...its the wiring and the poppers that cost alot. recommended poppers are the ones from autoloc...every day use requires the 50lb silenoids. runs about 300.00 bucks.
Old May 17, 2001 | 06:15 PM
HOSRACN's Avatar
Post
where is a good place to buy the kit? or is it better to see if the shop can get it for cheaper? anybody happen to know approx charge for filling holes behind emblems?
Old May 17, 2001 | 08:33 PM
2manyBLackf150's Avatar
Post
I disagree with the post that it shouldnt cost anymore to get the handles shaved if you are already repainting it. Shaving the handles would cost a considerable amount of labor. The paint wouldnt be any extra charge but the labor is high. I had a quote of 525 labor and about 250 material to shave mine due the the curves of the door thought that was quite reasonable. but not in my price range.
Old May 17, 2001 | 08:42 PM
zeroxman1's Avatar
Post
I have owned 2 cars with shaved handles and here is what it ran me: About an average of $250.00/handle which included the paint and clear coat. The thing is, it takes a real good "body person" to do this because when they weld in the filler panels, it has to be done very slowly and very gently because the constant heat from the welder will shrink the metal and cause the panel (door) to warp. The more you warp, the more Bondo body filler you get. It is a time consuming process and not EVERY body shop can do it. Shop around and find yourself a good ole Hot Rod shop or Hot Rod guy to ask him where he gets it done at. Also, on the door poppers...here is what I used: A Viper alarm with extra outputs (any good RELIABLE reliable alarm will do as long as it has extra outputs available. For "poppers" I actually used OLD Volkswagon Beetle starter solenoids. The end of the solenoid has a threaded shaft that I used to install an L bracket to and bolt it on using the existing threads in the solenoid. Obviously I had to fab up some brakets to bolt inside the door body to mount them. Finally I used some 1/8" cable and cable ends to secure the latch ends to the solenoid ends for the means of "popping" the door latch. If you have your stereo shop or alarm installer do the wiring UP TO the inside of the door, all you do is ground the solenoid and connect the lead from the alarm (actually from a relay)to th solenoid and its good to go. Sorry so long, hope it helps.
Steve
Mine:
1999 F-150 Sport Supercab
Bright Red 4.6L Auto
Billet Grill, Billet Ant, Clear Corners, Sony CD Player, Pioneers in all doors, Kicker 100si Amp, MTX preformed underseat box. Fiberglass Bed Cover
Hers:
2000 Expy Sport
Black, Grey Leather 5.4L
Clear Corners, Alpine CD Player, Punch 150 Amp, JL Audio preformed sub box in rear panel.
Old May 17, 2001 | 11:37 PM
LoCo F150's Avatar
Talking
I guess the reason i say it doesnt cost extra to shave the door handles but to install the kit is because im getting my whole truck painted with ground effects, shaved antenna, door handles, gas tank, molded ground effects for only 1800.00. The guy told me that anything i want shave isnt gonna cost me extra. You can get the kits at www.autoloc.com
97 4.6L F150 Super Cab Lariat
Current Mods
- Billet Grille
- PIAA 9007's
- APC Euro Altezza Tailights
- APC 5 Color Indiglo Gauges
- Trenz Billet Antenna
- Dual Exhast
- APC Clear Corners
- Glowing Ford Logos (front and back)
- Lighted Pinstripe
- Chrome Wiper Arms
- Ventshades
- Billet Aluminum Door Locks
- Powered by Ford Seatbelt Pads
Soon To Come:
- Roush Ground Effects
- New paint job with shaved gas tank and handles
- carbon fiber dash kit
- billet aluminum vents and ac/heater *****
- Superchip
- Airforce 1 intake
Far Future:
- 20 inch Titans or T-rex's
- Bagging it
- Hella loud system
Old May 22, 2001 | 09:47 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
Post
post a pic and i'll shave everything for you so you know what it will look like... in photoshop i mean
click my truck below and close note at bottom then click "Photoshop Truck Pics" to see some shaving
TRUCK
White 00' XLT 4.2 Auto Sport
Regular cab Styleside[*]Superchip[*]Airaid FIPK[*]Gutted MAF[*]custom Ported STOCK Throttle Body
<A HREF="http://www1.eboard.com/eboard/servlet/BoardServlet?ACTION=NOTE_SHOW&ACTION_ON=NOTE&OBJEC T_ID=362221&SITE_NAME=Destination&BOARD_NAME=sandr apics" TARGET=_blank> </A>
1/4... 17.221@81.35MPH
PC
Thunderbird 1.1ghz @ 1.33ghz
Abit KT7A-Raid
384mb Kingmax PC-150 ram
60gig IBM 75gxp RAID array
Geforce2 GTS 64mb
19" KDS Avitron Flatscreen
Old May 30, 2001 | 10:20 PM
ThePyroManiacKid's Avatar
Post
when i shave everything on mine (when i get another car to drive) it is going to cost me about $400 to shave the door handles, tailgate handle, gas filler door and paint the whole thing inside and out
$400= estimate cost of painting supplies
$0 = labor
gotta love my dad he just about started shaving car parts the same time he started shaving his face .... lol
whats really hard i shaving the drip rail on a 67-72 chevy pickup while you are slightly chopping it
