System
Old Nov 11, 2010 | 10:42 PM
jpf150's Avatar
Wow haven't updated this, I ended up getting the pioneer p3200bt for my head unit. I am now making my christmas list and will be most likely getting an amp and subs. I am going to do the speakers last, but possibly at the same time I do the subs depending on money. I did some research and found these
http://www.gooddeals18.com/product/P...etacpg=P3SD410
think 2 would sound good and fit good?
also I am undecided on an amp. I think I am just going to go with a 2 channel(correct for 2 subs?) for the subs.
any suggestions or comments feel free to leave them. I need input.
Thanks, JP
Old Nov 12, 2010 | 04:41 PM
Gtullous's Avatar
Those are the same subs i have...i think they sound great.....mine are in downfire boxes with a 500w 2channel Rockford amp bridged for power...i have a 400w Rockford 4channel for the front and rear Rockford door speakers....the head unit is a pioneer 4200dvd...i still need to do some fine tuning on amps but the system sounds awsome.....and it all fits under the backseat....
Old Nov 12, 2010 | 05:21 PM
jpf150's Avatar
nice! thanks for the info! How much power do you have running to each sub?
Old Nov 12, 2010 | 09:13 PM
Gtullous's Avatar
Not sure what each sub gets but the specs on the amp says 500w x1 @ 4ohms so in theory i guess they both get 500w? not sure how that works...
Old Nov 14, 2010 | 02:16 PM
DirtySCREW's Avatar
From my understanding if you have 500w x 1 AMP and you have 2 subs, each sub would be getting 250w (500/2) and if you have 3 subs about 167w (500/3) etc etc.---DirtySCREW
Old Nov 14, 2010 | 05:53 PM
jpf150's Avatar
Thats what I was thinking...so do I need a 2 channel for 2 subs?
Old Nov 15, 2010 | 02:07 PM
DirtySCREW's Avatar
No, you don't NEED a 2 channel. Again, from my understanding, normally a Mono amp is more efficient. Just remember that whatever the RMS power is will be divided by how many subs you have. If you have a 1000w mono RMS amp and 2 subs, each sub will get 500w RMS...and your subs had better be able to handle the amps RMS load.---DirtySCREW
Old Nov 15, 2010 | 07:15 PM
jpf150's Avatar
alright thanks. Im looking at the rockford shallow 10s like gtullous has
Old Nov 15, 2010 | 08:11 PM
Ford12508's Avatar
Your subs will hardly ever see full power, unless you have everything turned up 100% and it is a deep song. Really the only time that RMS power is actually used is when burping, otherwise it is just a quick hit here and there. My currently amplifier is rated at 9.1kWs @ 1ohm, and I am probably just going to put in 2 12s. I bought it figuring that I can upgrade to 4 12s later on if I want too. Just make sure all the settings are correct, and the subs and amp(s) should be fine.
Old Nov 15, 2010 | 08:26 PM
jpf150's Avatar
so what size mono amp should I get for these 2 10s? max is 600 and rms is 300. I was thinking just a 500 or 600 watt. Oh and these are 4 ohm
Old Nov 15, 2010 | 09:15 PM
ford4life.'s Avatar
for a heads up.. there will be some trimming when installing you 3200BT..
Old Nov 15, 2010 | 09:20 PM
jpf150's Avatar
already got it in
Old Nov 18, 2010 | 08:38 PM
joh408's Avatar
Go with 600 or higher. If you go higher than 600, make sure to set your gain down
Old Nov 18, 2010 | 09:21 PM
jpf150's Avatar
so will this work?
http://www.sonicelectronix.com/item_...ch+P500-2.html
any suggestions for amps?
Old Nov 19, 2010 | 08:23 AM
Ford12508's Avatar
Why are you running it in 4Ohm? that amp you posted is only 125W when its 2 channels and 4 ohms.
