Electric Fan Install (Pics & Vid)
Old May 17, 2013 | 11:22 AM
  #151
chengjj3's Avatar
Originally Posted by gofast302
The measurements for motorcraft 2010 efan is 2'8" long 1'4" tall and about 5" wide. You will have to do a lil cutting and trimming but nothing major.
Gofast302,
Thanks for info. Purchased one from ebay. Yes it will work. Has not installed it yet. Started installing the controler, waiting for fan plugs from amazon.
Sorry did not get back with you sooner.
Old Apr 6, 2014 | 06:43 PM
  #152
drew1414's Avatar
sub
Old Nov 17, 2014 | 09:08 AM
  #153
twinskrewd's Avatar
Double post
  #154
twinskrewd's Avatar
Quick update. The fans are down to $125 at Tasca. Here's a link. Mine have been running 3yrs strong. No regrets here.
http://www.tascaparts.com/oe-ford/al3z8c607a
Old Nov 17, 2014 | 11:38 AM
  #155
Jesusfrk's Avatar
You're killing me, man! All these great mods! I'm going to have to come down to your place to help me install this stuff!
Old Nov 17, 2014 | 07:05 PM
  #156
tbear853's Avatar
OK ..... Santa is due soon ....
Old Nov 24, 2014 | 08:26 AM
  #157
rino2098's Avatar
? on the fans
I got a set from the junk yard that came out of a 2010 F150. But the only thing is they are loud. Kind really loud. Are yalls loud? don't know if I got a bad set of fans or if it normal. Thanks
Old Nov 24, 2014 | 08:54 AM
  #158
VTX1800N1's Avatar
They are if you run them at full speed.
Sent from my XT1080 using IB AutoGroup
Old Nov 25, 2014 | 09:13 AM
  #159
gofast302's Avatar
Controller
What controller are you currently using? I installed efan from a 2012 f150 on my 08 lariat with a MADD enterprise controller that now only turn the fans on when the air condition is on. Thanks
Old Nov 25, 2014 | 09:17 AM
  #160
MGDfan's Avatar
Normal. They move serious air @ full song, as well as draw enormous current.
That is only one reason of several why you need to use a constant-temperature, variable-speed controller.
MGD
Old Nov 30, 2014 | 07:26 PM
  #161
twinskrewd's Avatar
Would be happy to help.
Old Nov 30, 2014 | 07:29 PM
  #162
twinskrewd's Avatar
I am using the Painless F5 controller. Works like a charm.
Old Nov 30, 2014 | 07:30 PM
  #163
twinskrewd's Avatar
MGD
Correct. The only time they are semi-quiet is when they are at 50%. Which btw is most of the time.
Old Jan 8, 2015 | 09:32 PM
  #164
jcellini's Avatar
Did you go back to the original location for the a/c wire after the one at the black box didn't work? You stated the voltage may fry the controller so i'm not sure where to tie that one in.
Old Mar 29, 2015 | 04:51 PM
  #165
twinskrewd's Avatar
Yes I am using the wire at the compressor.
