E3 Spark Plugs
Old Jan 18, 2011 | 08:39 AM
  #136
sam1947's Avatar
Originally Posted by thomabro
ok so not to highjack the post (ill start another post if need be) but it turns out the truck is still acting up when cold... it shakes hard,... hard enough for the headers and and exhaust pipe rattle and hit the frame rails. it only does this under about 1800 rpm and below about 175 degrees.
Start by putting back in the original COPs, or as many as you can (I know you broke one). I don't think it's the plugs unless the tip of one got bent ?? Just start eliminating items one by one..did you clean the MAF ??
Old Jan 18, 2011 | 02:34 PM
  #137
thomabro's Avatar
havent cleaned the maf, it just started after the plug and coil change,... it is still doing it today but it is not as bad as it was.
Old Jan 18, 2011 | 06:53 PM
  #138
sam1947's Avatar
Don't know what to tell you other than check everything again. Could be one of the new COP's is bad, but that should throw a code up. Worse case scenario, put the Motorcraft plugs back in and try it (or some known good coils). I do know even one coil or plug not firing will shake like (you know what). Best of luck and keep us posted.
Old Jan 18, 2011 | 10:59 PM
  #139
thomabro's Avatar
ok, i have tomorrow off, so ill check it all after im out of class. i just cant believe there is no code for as bad as it misses. however im still optimistic. it didnt shake at all after work today and only stuttered for about 5 feet. thank yall for all the help
Old Jan 23, 2011 | 02:02 PM
  #140
thomabro's Avatar
im gonna start a new thread in the v8 section so this one doesnt get any further off topic.
Old Jan 25, 2011 | 08:49 AM
  #141
Devildog101's Avatar
I am curious to see if this has anything to do with the mix of the e3's and a gryphon. Maybe flash the truck to stock and then drive it around to check that out. If not, do as Sam said and re-check everything sense you have isolated to that timeline.
Good luck and keep us posted.
Devildog101
Old Jan 25, 2011 | 09:04 AM
  #142
poolboy1191's Avatar
Devildog101
I just read a post he just made in the V8 Forum, His truck finally threw a code yesterday.
Coil #8 is bad.
But, I'm not sure what his plan is yet. He didn't include what he was going to do.
Old Jan 25, 2011 | 09:55 AM
  #143
sam1947's Avatar
I have a Gryhpon on my truck..had no effect with the E3's..just better MPG overall. Hopefully he has found the problem with that coil.
Old Feb 20, 2011 | 10:18 PM
  #144
thomabro's Avatar
ok, so to update, i replaced coil #8 and 4 others with some original coils and it still didnt fix it, the problem was the plugs themselves..... yall can check my thread in the V8 section to see the whole problem and pics of what happened. I am going to start writing emails and making calls and see if i can get my money back for the defective plugs.
Old Feb 20, 2011 | 10:30 PM
  #145
sam1947's Avatar
Yep...going to pull my endorsement for the E3's myself also!!...have replaced them with the SP-515 W/Weapon-X COP's, gonna give these a try.....
Old Feb 21, 2011 | 03:38 PM
  #146
thomabro's Avatar
so looking around on e3's website. they dont provide an email address or phone number, and most if not all of their plugs have a warranty.... except for 3.70... ok so i emailed e3, and a rep. called me within 15min of the email. He then sent me a warranty form and told me that it did sound like the plug was at fault and if i can provide him with the plugs and recipte then he would refund me, if not then all they can do is replace them. So even though the plugs are faulty at least the customer service is good.
Old Feb 21, 2011 | 08:14 PM
  #147
Sam,
Were all your plugs still intact? Or was the porcelain loose too??
Thomabo,
I'm glad to hear that they are willing to work with you. I ordered 8 of their plugs about 2 weeks ago. I have them sitting in my garage, waiting. I think I am going to try them still with Original COPs and see how they are.
Speaking of which, are you going to be using your Global COPs still? or all Motorcraft??
Old Feb 21, 2011 | 08:32 PM
  #148
sam1947's Avatar
poolboy.....all of the plugs were intact when I pulled them out...I was starting to get a slight roughness when idling, then I have been keeping up with Thomabo's problems and decided to check mine, was going to put them back, but had some new SP-515 on the bench and went back with those and in the process installed the weapon-x COP's with them. Real "seat of the pants" change so far, and the roughness went away. It might have been just me, but I never had a real 'warm and fuzzy' feeling with the E3's. It's too bad..we need a good quality one-piece plug from Motorcraft !!!
Old Feb 21, 2011 | 08:39 PM
  #149
I wish I had your money man! lol.
Like I said, I think I'm going to try them. But will in no way endorse them.
What is the difference between 507's and 515's?
I take it that you like your Weapon-x's lol.
Old Feb 21, 2011 | 08:53 PM
  #150
sam1947's Avatar
I don't have money !!!!!...LOL, Just plastic and a decent income. SP-507= platinum plug; SP-515= double platinum plug (longer lasting). WAY too early for an eval on the Weapon-X, just got them in, but so far so good..in part it might the new 515's also....who knows. ??
