people with e-fans..are you satisfied
Old Feb 24, 2008 | 02:12 PM
  #76
ScottFF00's Avatar
Anyone with the an '04 or newer. Where did you make your AC and 12v connections for the fan?
FAL270 instructions only cover the 97-03 model. Fuse panel seems to be different.
Old Feb 24, 2008 | 04:43 PM
  #77
lenore's Avatar
I piggyback the 12v line on the wires going to the compressor for the AC and piggyback the ign line to a wire in the plug up by the battery and firewall. There is a plug which hangs there and I found a switch 12v wire. Sorry I should have taken pictures.
Old Feb 24, 2008 | 04:48 PM
  #78
lenore's Avatar
Talking
Originally Posted by ELVATO
No worries, I got an email last night that it was going to be shipped
From CA to FL by USPS, I wonder how long that will take....
two to three days, he sends them priority mail...
Old Feb 24, 2008 | 08:00 PM
  #79
ELVATO's Avatar
That's good to hear
Old Feb 26, 2008 | 11:11 AM
  #80
ScottFF00's Avatar
Does anyone have a picture or can take a picture of where they tapped the 12v on source for an '04 + F-150?
Old Feb 26, 2008 | 12:11 PM
  #81
Big Slick's Avatar
Originally Posted by lenore
Update, I put a diode across the motor, but that is not problem, fan is turning in same direction as when turned on. So I guess the LED indicator is just going to tell me that it is freewheeling sometimes. I will call DC controls and ask about this. No real problem as the Lincoln fan is working great. Love the throttle response. And the truck is noticeably quieter. Engine is staying right at temp. My $169 kit rocks bigtime so far.
where did you get the Mark VIII fan? junkyard?
Old Feb 26, 2008 | 08:44 PM
  #82
lenore's Avatar
Yes the junkyard, but I have discovered that the later model thunderbirds with the v8 also have the exact same fan as the MARK VIII. A 18 inch seimens motor that puts out 4300 cfm. Just a side note: the Fan in my Truck originally was only 19inches. interesting....
Old Feb 26, 2008 | 09:01 PM
  #83
lenore's Avatar
yes go in my gallery and look at the picture that I just took labeled e fan accessory on plug. My hand is actually holding the plug....with the Red with yellow stripe wire showing in the corner of the plug.
Old Feb 27, 2008 | 07:35 AM
  #84
ScottFF00's Avatar
thanx
Old Feb 27, 2008 | 07:51 AM
  #85
MSH's Avatar
MSH
Old Feb 27, 2008 | 09:10 AM
  #86
lenore's Avatar
Originally Posted by MSH
Is it recommend that you upgrade to a heavy duty alternator due to the increase el. draw?
that is why I went with the DC controls controller, It soft starts the fan and speed controls the fan, at 3700cfm the Lincoln fan is only drawing 15amps. But it also depends on what you have put in your truck, If you have a sound system that draws a lot of juice, the alternator can strain real fast.
Old Mar 3, 2008 | 05:29 PM
  #87
Big Slick's Avatar
thanks man. one more question. how well did the mark viii shroud bolt up to the radiator? is it my imagination or did i read somewhere that the shroud had to be modified?
Old Mar 3, 2008 | 08:34 PM
  #88
lenore's Avatar
Yes I did, I made mounting brackets of my own design. See my gallery pictures. Nice thing is just two screws and unplug the original lincoln fan connector and the whole things comes out for service....take a look at my pictures.
Old Mar 4, 2008 | 02:39 PM
  #89
Jordan not Mike's Avatar
I had dual fans, and steggered the turn-on temps just a little bit...so that they didn't turn on together at the exact same time.
Old Mar 10, 2008 | 08:52 PM
  #90
mjt123's Avatar
I was think of getting this setup any thoughts would be great.
Fan Kit Derale 16934 or Derale 16928 at Summit for 209.00
And the SPAL Electric Fan Controller (FAN-PWM)
My spec 5.7 S-Cab
Thanks Mike
