Help kenwood dnx7100
Old Mar 21, 2009 | 09:04 PM
04 f150 fx4's Avatar
Hi Guys, I have an issue. I have the kenwood dnx7100 installed in my 04 fx4. I blew a fuse a couple of days ago and the whole system stopped working. Easy enough change a fuse and im good to go right.... Well i checked both fuse 31 and 7 and both are good and the fuses on the h/u that i found are good. The unit will still open and close but i get a flashing red light from the bottom left side of the unit. I was curious if anyone had an ideas or thoughts as to what the problem might be. Thanks guys hopefully you can help me.
Old Mar 22, 2009 | 01:46 AM
Low_e_Red's Avatar
Holla at KCAutosound. He's a huge Kenwood dealer and would know about those. Have you tried resetting it?
Old Mar 22, 2009 | 01:50 AM
i tried resetting it and that is when the red light starts blinking which i am guessing is some form of protect mode and when it will eject a disc.
Old Mar 22, 2009 | 01:55 AM
Low_e_Red's Avatar
Man, I honestly dont know crap about Kenwood's error screens/msgs. Have you unplugged it, waited 5 min then plugged it back in?
If that doesnt work, Holla at KC. Then, next would be call Kenwood.
Old Mar 22, 2009 | 02:33 PM
05RedFX4's Avatar
I have the 7120, vitually the same hu. Mine did the exact same thing one day and it was fuse 31.
Looks can be decieving, swap in a known good fuse and see what happens.
Old Mar 23, 2009 | 04:18 AM
KCAutosound's Avatar
As stated before. Check the fuses again. Take a simple test light and probe the tops of the fuses on both sides. If you haven't noticed there is a small bit of metal on the top of the fuse so that you can probe it.
If all fails then remove the radio and check your red wire on the radio harness and make sure there is power there with the ignition on.
If that fails then call Kenwood's Tech Line at 310-763-1406
Old Mar 23, 2009 | 05:56 PM
well guys thanks for the help. still hasnt fixed it yet but i want to try the factory radio to see if the issue is with the truck or the kenwood unit. Just bad timing because now i have to drive eight hours with no radio.
Old Mar 26, 2009 | 02:50 PM
well it turns out it was fuse like 22 i think. The problem now is the screen will not close after it is opened...anyone have any ideas about this.
Old Mar 26, 2009 | 05:34 PM
05RedFX4's Avatar
try resetting the unit again, the button on the lower left corner of the screen.
Old Mar 26, 2009 | 07:04 PM
Sundevil2188's Avatar
Test Lights FTL...especially in the hands of someone who has no clue of what it can potentionally do. DMM or bust...
Old Mar 26, 2009 | 07:13 PM
There is nothing wrong with using a test light to test the fuses. Sure a meter is the recommended tool but some guys just don't understand how to work a meter. Test light on...it's good, Test light off....no good.
04 f150 fx4
You may have woke up a problem that was in some of the DNX7100s and the DNX7019s of that year. I had a few that I sold or installed that once they were powered up and the screen dropped they would not return to the closed position. Out of the 50 or so of them I sold that year I had about 6 or so that had this problem. The only way a customer could get it to close was to turn the truck back off and it would close after powering down. These radios were under warranty back then and Kenwood would replace them for me. Being that your unit is out of warranty I would suggest contacting the tech number I mentioned above and see what can be done about this problem.
