Tidewater VA
No, it's mostly new construction around here.
There are some old places but, they are kept up pretty good.
Any ruminants would get bulldozed and they'd just build a shopping center.
They must be some pretty tough and or stubborn ruminants to get bulldozed. We moved ours with a handfull of hay or a bucket of food. Must be a P-ninsula thing.
... shoot yeah!! I must say that was a low blow though, you went straight for my weekness
Wow look at all the FNG's!
Changed the fluid in my front and rear diffs yesterday on the ole onefiddy....front was "easy", relatively speaking. The rear on the other hand could benefit from a drain plug. I ended up pulling the VSS and using a vampire pump to get the fluid out of the rear. It was that or break the seal on the diff cover.
Transfer case is next, and then to do all it again on the Expedition.
Do you have any pictures of it?
