Removing 4# JDM pulley??????
Old Aug 27, 2002 | 08:48 PM
Crazyone's Avatar
Hey guys.
Friends truck is needing service and guy at shop wants all mods off so he can troubleshoot., I just broke a snap on ratchet trying to get it loose,
I am not on a 1/2 18 inch breaker bar with an extra 5-8 inches of bar on it, and cannot BUDGE this *******ing thing. Bolt is starting to strip off.
Any other ideas? I think even with a pipe wrench it'll just slip around and ruin the pulley.
Please any suggestions drop me a line or call me
Thanks in advance!
Brandon
Crazyone@forcedinduction.com
859-227-1466
Old Aug 27, 2002 | 08:50 PM
svt4rd's Avatar
pulley
The 14mm is reverse thread make sure you are turning it counter clock wise to tighten and clockwise to loosen!
James S.
Old Aug 27, 2002 | 08:55 PM
Crazyone's Avatar
Svt, well this is a JDM 4# pulley, and i we are turinng it clockwise to remove (well at least trying) my 19mm was the tightest fitting socket i could find and it's still starting to round it off.
Brandon
Old Aug 27, 2002 | 08:59 PM
svt4rd's Avatar
don't know what to tell ya.... you might want to break out the tourch and get some heat on that thing.
Old Aug 27, 2002 | 09:00 PM
Crazyone's Avatar
yeah thats the last resort when i round this bolt off and have to use the pipe wrench.
B randon
Old Aug 27, 2002 | 09:31 PM
MRBBQMAN's Avatar
Wink
save some time and get out the 24" pipe wrench. heat doesn't work. you can clean up the wrench scars later
Old Aug 27, 2002 | 09:38 PM
mecca's Avatar
Thats one bad lookin pulley....
-Mike
Old Aug 27, 2002 | 10:04 PM
Crazyone's Avatar
Thats not bad lookin at all
ours IS bad looking now, the *******in pulley now BARELY spins, but the crank sits stilll, AND the hub has not moved which means if there was a keyway its now broke. ANy other solutions guys??
Brandon
Old Aug 27, 2002 | 10:39 PM
Crazyone's Avatar
ok this thing sucks. tomarrow we are going to have to cut the pulley off and hope we can get the cage off to get to the 3 hub bolts...
ANy other suggetsions are welcome and appreciated...
Brandon
PS jdm these are some nice parts, they are THEFT PROOF!!! GUessing you dont warranty these when someone can't get them off without ruining them???
Old Aug 28, 2002 | 01:15 AM
Crazyone's Avatar
BUMP
Old Aug 28, 2002 | 01:31 AM
Silver_2000's Avatar
Of course you remember it is reverse threaded... Get the cheater on it and put some pressure on it then have someone tap the shaft to get it to break loose... The 450 ftlbs gets it pretty tight
Also it should be possible but not easy to remove the 3 bolts (if you have 99-2000 ) with out removing the pulley. Just take 3 cage bolts off and use offset wrnech to try to get bolts.
Good Luck
Doug
Old Aug 28, 2002 | 06:03 AM
Fast Gator's Avatar
Any luck yet? Hope it doesn't end up looking like Dougs pulley
Old Aug 28, 2002 | 07:35 AM
wydopnthrtl's Avatar
Question
This makes me want to ask, if there is some kind of anti-sieze I should apply before I do mine?
WOT
Old Aug 28, 2002 | 07:52 AM
BadAzz516's Avatar
Rest In Peace
Also it should be possible but not easy to remove the 3 bolts (if you have 99-2000 ) with out removing the pulley. Just take 3 cage bolts off and use offset wrench to try to get bolts.
Good Luck
Doug
Just like Doug said it is possible to remove the 3 bolts without removing the pulley. When i was at JDM's and they were taking off my stock lower that the dealer put on for me when i had problems with my truck. They couldnt break it lose for *****. So they did exactly what Doug said and took the 3 bolts off without taking the pulley off. So just goes to show you its not just aftermarket pullies that are a bitch to get off stock ones can be just as much of a bitch if not worse.
Old Aug 28, 2002 | 09:19 AM
Crazyone's Avatar
well this is a 2k2, and i've tried to get to the bolts, no way to get at them =(
We gave up at 11, We beat, pryed, heated, pipe wrenched it all, and as i said, the PULLEY now turns, crank sits still, and hub still remains seated on crank. Soo the keyway or whatever is in there is now snapped (that ******er is on there)
Only thing i can think of left to do is hit the front side of the cage with the sawzaw, and attempt to get at the bolts. Pulley is most certainly going to be ruined after we get it off. =/
Brandon
