Switched to Mobil 5w30 SuperSyn w/ K&N filter
Old 07-18-2002, 12:58 AM
brasil's Avatar
I just changed my oil to the new mobil supersyn w k&N gold oil filter. They do not have 5w20, so I had to use 5w30. Any disadvantages of running 5w30 instead? The engine seems to be running a little smoother and quieter (of course it could be psycological).
Later
Old 07-18-2002, 05:58 AM
Probleminfected's Avatar
most people run 10w-30 or 15w-50 so not you won't have any problems.
Old 07-18-2002, 07:44 AM
02Thunder's Avatar
You are perfectly fine using Mobil 5w30 in your L.
joe
Old 07-18-2002, 08:03 AM
wydopnthrtl's Avatar
I asked around here (ford) and the 5w-20 thing is nothing more than for fuel economy.
I'll be switching to 5w-30 mobil 1 at the 2,500 mile mark.
WOT
Old 07-18-2002, 10:50 AM
slapshot's Avatar
I have heard of some leaking problems after changing to synthetic, has anyone here had any problems??
I have 22.5k miles on my 99 now and plan to swicth to Mobil on my next oil change. As far as I know, it has always had normal oil in it.
Old 07-18-2002, 10:53 AM
animal's Avatar
Hey brasil... I think we're modding at the same rate... I just made the switch a week ago as well. Now you need the bassani... just ordered mine
Old 07-18-2002, 10:58 AM
LIGHTNINROD's Avatar
If all your eng. gaskets and seals are 'whole' and in place, you won't have any leaks. Syn. oil has a more aggressive detergent agent to clean the eng. better and sometimes can remove an oil contaminat that is blocking a potential leak. The detergent might dssolve this contaminat opening up a leak........
There are no disadvantages to using a synthetic oil, only advantages. I started with Mobil 1 in the 70s and every vehicle I've owned has benefited from it.
Dan
Old 07-18-2002, 11:04 AM
BfB's Avatar
BfB
BfB is offline
Banned For Rules Violations
5w-20 not only gives a tidge more fuel economy (you'll never notice it), but it is thinner so more performance should be afforded as well.
I recommend Royal Purple 5w-20. It's new so most will not have that viscosity in stock. They can order it, though. Go to www.royalpurple.com
I know all synthetic oil manufacturers claim their's is the best, but I honestly believe you can't do better than RP. It's price is about 5 bucks a quart, too. Hardly anymore than a bottle of Mobil 1.
Old 07-18-2002, 11:33 AM
blown318's Avatar
Thumbs up
I agree with bfb!! royal purple is the chit!!!
Old 07-18-2002, 04:07 PM
brasil's Avatar
I bought the mobil supersyn at costco (6 quarts for $21.99), so it was quite a bit cheaper than $5 per quart. ANimal, I will be deciding on the exhaust soon. Let me know how you like your bassani.
Later
Old 07-18-2002, 06:48 PM
99 SVT Bolt's Avatar
38k and no leaks yet.
Old 07-18-2002, 08:00 PM
BADBOLT2's Avatar
I would stay with the Motorcraft 820s filter.It has a silicone anti-siphon valve it it.
have heard of many having the "can of marbles' sound develop with aftermarket filters.Myself included.Swithed back and it went away.
I also Pre-fill the filter with fresh oil before install.It'll take almost 3/4 qt.Then before you start the truck,hold the accelerator to the floor and crank it over for 30-45 sec.then let off the accelerator and start as usual.
hope this helps!
Old 07-18-2002, 08:08 PM
JBLsilver01's Avatar
Thumbs up
Just changed my oil and Motorcraft filter two hours ago. Been using Mobil 5w-30 for about 17k w/no leaks, always has ran smooth and quiet.
Old 07-18-2002, 09:22 PM
BfB's Avatar
BfB
BfB is offline
This will keep the truck from cranking?
Old 07-18-2002, 09:35 PM
SLP 97 CAMARO SS GUY's Avatar
Question
yea, i didnt understand that part either..
Quick Reply: Switched to Mobil 5w30 SuperSyn w/ K&N filter
