2003 5.4 lightning motor in 1956 ford f100
Old Feb 3, 2011 | 11:19 AM
spany58's Avatar
I am starting a 1956 ford f100 project and have purchased a 5.4 sc lightning motor with 4R100 transmission. The truck has a Volare front end now. I have the wiring, exhaust, fuel lines and ECM complete from donor truck. Is there a company known that can help with conversion and what items can be stripped ? Any help is appreciated.
Old Feb 3, 2011 | 12:46 PM
Veteran: Army
madenterprise can hook you up, what are you using for a dash? are you going to change the rods and port the heads while it's apart? what year of setup do you have??
Old Feb 3, 2011 | 04:39 PM
Marc Carpenter's Avatar
Why not modify the '56 F'r to fit on the Lightning frame like someone I know has been working on for over two years now
Old Feb 3, 2011 | 08:17 PM
spany58's Avatar
It's a 2003 5.4 lightning with the supercharger. I thought about graphting in the front frame but I haven't measured the width.
Old Feb 4, 2011 | 07:25 AM
Using the entire Lightning frame and and drivetrain is possible, however you better be ready for a LOT of modifications and fabrications.
Old Feb 4, 2011 | 08:59 AM
jetcycles's Avatar
I'm not sure what "look" your going for with the build but if you're into traditionally styled trucks/hotrods/customs you can probably find tons of info by joining the H.A.M.B. over at www.jalopyjournal.com TAKE NOTE: make sure to introduce yourself, use the search button and read EVERYTHING before posting repetetive questions and be courteous. That forum demands respect. . .its also the #1 source of pre 1962 auto information in the country!!!
Old Feb 4, 2011 | 11:45 AM
Veteran: Army
so you have the entire truck???
Old Feb 4, 2011 | 01:26 PM
spany58's Avatar
I've got the frame excluding the front suspension with the frame being cut just behind the transmission shaft. I have the complete wiring harness from the truck, exhaust and fuel lines also.
Old Feb 5, 2011 | 11:33 AM
Jkstang78's Avatar
This link might help you out. Try and contact this person for ideas and help
http://callahanracing.myvnc.com/pictures.htm
Old Feb 5, 2011 | 12:28 PM
Veteran: Army
what are you planning on using to controll the motor and transmission??
also what are you going to use for guages?
Old Feb 7, 2011 | 08:38 AM
spany58's Avatar
I was going to use the Dakota Digital Gauges and I have the complete wiring harness. Ron Francis told me they could build a engine and trans. harness but I'm open the suggestions with anyone else. This engine is from California and my big question is what items can I striff off the motor without having computer problems.
Old Feb 7, 2011 | 03:38 PM
Veteran: Army
the EGR, the power steering, the cats, the a/c to name a couple easy ones
Old Feb 10, 2011 | 10:58 PM
lightninquick's Avatar
looks right at home in there
Old Feb 11, 2011 | 01:25 AM
spany58's Avatar
Thanks for the picture and link it is greatly appreciated
