Lightning motor swap into regular F150
Old Jan 25, 2006 | 07:13 AM
FunFord's Avatar
Registered User
Originally Posted by kromdom
he is almost done converting his '00HD to a supercharged one: not a cheap project (and he is practically doing ALL the labor and getting USED parts/pieces):
http://www.nhtoc.net/vbforum/showthr...threadid=24906
http://www.nhtoc.net/vbforum/showthr...threadid=24391
http://www.nhtoc.net/vbforum/showthr...threadid=24159
He is going to list a complete breakdown of every little thing he needed for this project plus costs involved.
Thanks, great info!
Old Jan 25, 2006 | 09:23 AM
raider's Avatar
Originally Posted by Neal
HI!... Actually your both wrong. I built up a N/A 5.4 that makes AROUND 425H.P (flywheel) with turbo cams and only 8.42:1 compression. Turbo will be coming later on this year. Hope to make 650RWH.P under 18PSI.
who cares? has nothing to do with this thread or a L swap
Old Jan 25, 2006 | 09:41 AM
brahmus's Avatar
Originally Posted by kwilt
on the motor mount thing, one of my friends from the harley site just installed a lightning motor in his 2000 harley truck and the drivers side mount he has for his regular 5.4 didn't fit around the oil cooler, so i guess you don't need a new mount if you don't use the oil cooler
That is correct!
Well with the Monster box 4r70W There is a cheaper alternative. The stock Lightning block can handle about 450rwhp safely and so can a built 4r70w. In my opinion, if you aren't going with a built block don't do the whole swap. If you already have a 5.4 all you need is the upper setup like they sell on ebay all the time. If not you can pick up a low mileage JunkYard 5.4 fairly inexpensive will all you'll need. The little details can be had at Madenterprise.com.
Old Jan 25, 2006 | 01:15 PM
mark150's Avatar
What ever happened with jon jons supercharger install that hydrolocked the engine and windowed the block? Did he give up or have someone else finish it. Last I saw he buying a L engine.
Old Jan 25, 2006 | 03:03 PM
raider's Avatar
he bought a new motor from Mike at Madenterprise
Old Jan 25, 2006 | 05:52 PM
Neal's Avatar
HI!... RAIDER : You need to learn to read. My name was brought up and FALSE info about me and my truck was posted. I corrected it. Pretty plain and simple........................
Old Jan 26, 2006 | 03:23 PM
Eds 01 Lightnin's Avatar
This is a cool conversion on a F100! Check out!
http://mustangandfords.com/featuredv...ufp_0511_wolf/
Old Feb 1, 2006 | 03:00 PM
fordification's Avatar
Hey, I'm also looking at a powertrain swap in my 98 rc/fs 4x4. Does anyone have any links to projects? I stirred up the idea after seeing a damaged L going for 10k.
besides the driver side motor mount, was any other issues?
Old Feb 1, 2006 | 03:02 PM
I imagine you would have to swap in the L eec for the proper program. and is it the same 10.25" sterling diffy? have to find a 4.10 8" gears for the front also.
Old Feb 1, 2006 | 03:04 PM
Originally Posted by mark150
I'm doing a 4x4 right now. No picnic....but I knew that going in to it thanks to this site.
[IMG][/IMG]
[IMG][/IMG]
Hey Mark, do you have a breakdown for your project? was it the whole drivetrain you swapped?
Old Feb 1, 2006 | 10:31 PM
mark150's Avatar
Yes, it is the whole drive train. Well, eventually will be after I switch the rear axle. Converting the transmission to mate with the 4x4 transfer case right now.
[IMG][/IMG] [IMG][/IMG]
So far I have new longer torsion bars,4x4 tranny parts, different transmission mount, relocate oil cooler.......dead tired I'll finish list later.
Old Feb 1, 2006 | 11:03 PM
sadf's Avatar
Would'nt it be easier to just supercharge the current motor?
Old Feb 2, 2006 | 08:57 PM
mark150's Avatar
Yes, but then I would have a 4.6 engine that is leaking antifreeze with 154000 miles on it with a mazda 5 speed......No Thanks! Besides that I now have an excuse to disappear from the house when the wife starts thinking up projects for me.
Old Apr 30, 2009 | 12:43 PM
supercharged88's Avatar
Question 02 L motor and stock 4x4
Can i get a motor from an 02 L motor to pair up with a stock 4wd transmission from a 99 f-150, by reprogramming the ECU or something? The stock Ecu runs the tranny, but not the motor and the opposite with the L ECu.Thanks
Old Apr 30, 2009 | 01:43 PM
brahmus's Avatar
yes, you can use the F-150 computer, any good tuner can do this.
Not true, the ECU on both the L and F-150 are programmed to run both the motor and the tranny.
