Pro Turbo Kit
Old Aug 21, 2005 | 09:28 PM
  #31
ShockTherapy's Avatar
Originally Posted by Tim Skelton
Sounds reasonable on its face, but here is a consideration.
Do turbos use a bypass? If not, then they will be heating the air all of the time, right? An air-to-water cooler is best where the heating is intermittent.
Dunno, just raising the issue.
They don't heat the air unless you are in boost. The air just flows through like normal until you get into boost and it starts getting compressed.
Old Aug 21, 2005 | 09:59 PM
  #32
Tim Skelton's Avatar
How is the air bypassed from the compressor wheel? The hot side spins whenever gasses are flowing through, right? Doesn't that also mean that the compressor wheel is also always spinning?
Old Aug 21, 2005 | 10:07 PM
  #33
l-menace's Avatar
lets get back to my cam question.
Old Aug 21, 2005 | 10:43 PM
  #34
St Louis Lightning's Avatar
And that's the point I was making. You aren't going to find a cheap turbo kit if it's complete. PTK's price is not unreasonable. Try pricing a turbo kit for a C5 Corvette. Most of those are north of $10k.
Another example:
Nissan 350z kits - around $5000-5500 for single turbo kits with intercooler or $5500-7000 for twin turbo kits. Those companies are going to sell 10x's the kits though, so they don't need to make so much a kit to recover R&D.
Old Aug 21, 2005 | 10:50 PM
  #35
monkeysL's Avatar
Originally Posted by rmfreeze
Just curious, what would you sell the same kit for after you designed it, etc?
I think the majority of L owners probably won't take the time to research what parts are best, where to buy those parts for the best price possible, and take their trucks down for days/weeks for fabrication themselves (design, fitting, parts coated, etc). Some will. Most won't.
For those that do and say they did it for $3000 I am sure you are right. But you probably wouldn't sell the kit you designed without some type of markup. It's easy to enjoy the fruits of your labor knowing you saved money doing it all yourself but you spent considerable time - your time - in design and fabrication. For others, they might want to spend their time elsewhere (another project, a job that pays well, time with their family, etc) and pay someone else for the design and fabrication. It's up to the individual.
From what I've read on the various boards, I bet MANY people will pay $6000 for this kit and not bat an eye. $6000 isn't a lot compared to what some people have invested in these toys.
i'm not getting ahead of the game but there is another kit in progress for the L, not exactly for sure when its goin to be complete. i have been working with two local turbo manufactures on designing it. i figured i would use my non running sitting in the garage collecting dust L for something good! plan is to have it up and running by L fest and be there with some parts. three kits and maybe four versions all based off the same kit, stage I for stock blocks, stage II for built guys, STILL UP IN THE AIR stage III air-to-air, and a TT kit. stage I kit will be able to be upgraded at any time to II as well...like i said i don't want a IN TWO WEEKS thing goin on but its in progress.
*edit* prices are still up in the air as well but they are goin to be looking for more of selling large quanity at a lower price so more people can afford than HUGE pricesESTIMATES are:
stage I 4000-4500
stage II 4500-5000
Twins 5500-6000 ALL PRECISION EQUIPMENT USED
Old Aug 21, 2005 | 11:12 PM
  #36
svt450r's Avatar
I think the reason why the air isnt heated while not in boost is because when the turbo isn't in boost it is only spinning at 5000+rpm and when it is in boost its at 100,000+rpm
Old Aug 22, 2005 | 07:22 AM
  #37
jarmstro's Avatar
A N/A cam and blower cam are different from a turbo cam. Has something to do with the valves opening differently with a blower cam.
Old Aug 22, 2005 | 07:46 AM
  #38
1fst54's Avatar
Give me a month and I will show some Do IT UR self turbo kit.
I am tired of the wait from Mark & pro turbo.
Old Aug 22, 2005 | 08:46 AM
  #39
stage I 4000-4500
stage II 4500-5000
Sweet. Can you let us know what brand and model wastegates, BOV's, and boost controllers will be used?
Old Aug 22, 2005 | 08:50 AM
  #40
The compressor wheel is always spinning, but the air is only heated when it's compressed. Think of the comp wheel as a ceiling fan when it's not in boost, it's just moving the air, not heating it. The heat is a by-product of the air's compression during boost.
Old Aug 22, 2005 | 08:56 AM
  #41
brain bypass's Avatar
blower cams have a larger lobe seperation angle than N/A cams. blower motors don't need the overlap to help with evacuation, and would blow boost out of the exhaust valve. turbo cams have the wide lobe seperation angle like blower cams, but they usually have a longer intake duration to fill the cylinders more. turbo motors have a lot of exhaust back pressure.
Tim,
the bypass on the turbo is the wastegate. it serves two functions, it is open under part throttle to allow exhaust to bypass the turbine wheel and spin the compressor at very low rpms. it also regulates the boost level. with wastegate set to 8 psi, it begins to crack open at 8 psi to maintain that boost level, instead of the turbine rpm continuously climbing out of control.
Old Aug 22, 2005 | 11:07 AM
  #42
camcojb's Avatar
Spoke with Dalton this morning. He's sending me some pics of the kit and individual components. The pic on the main page is not Sal's truck, it is the kit. They are using the stock upper to keep the egr, etc. all in the stock location. Of course a C&L upper, or JLP sheetmetal intake could be used, but since it's now on the pressure side the restriction of the stock intake is not nearly as important.
The exhaust side will hook up to the factory or aftermarket catbacks and has no cats. I'll be adding a couple of high flow cats to mine.
I'll post pics up as soon as he sends them.
Jody
Old Aug 22, 2005 | 12:20 PM
  #43
KB ZILLA's Avatar
Jody
Awesome Jody...keep us updated.
Old Aug 22, 2005 | 12:31 PM
  #44
Casey02L's Avatar
Just curious; are they going to be using the same "hot parts" as they already sell for the 4.6/5.4?
And what size are the primarys and such, and down tube.
Old Aug 22, 2005 | 01:50 PM
  #45
Silver-Bolt's Avatar
Not entirely true. The air is being heated all the time. The temps do get higher as the boost goes up. Under boost I do not see the turbo discharge temp being less than the S/C. My turbo experience is limited to my STi. The discharge temps I see before the I/C are far higher than anything I saw on the L. Depending on the size of the turbo the stock water/air intercooler will work to a point. As the boost levels go up it will not be able to dissapate the heat and will also become an obstruction/restriction in the intake. Air/air is the way to go.
