32V Twin Turbo 5.4L Project - Pics and Commentary
Old Oct 12, 2005 | 09:50 PM
  #391
ZorPrime's Avatar
yeah what chim said. If i only had the cash...
Old Oct 12, 2005 | 11:44 PM
  #392
Casey02L's Avatar
Originally Posted by ShockTherapy
Actually Casey, the braking is a lot better without the ABS than with it. The pedal has a much better feel to it, and I get a lot better feel of what I'm doing with the brakes. I have gotten on the brakes pretty hard a few times to test it out. Works great!
That is basically what I thought would happen! The brakes just never have felt right IMO!
What parts/tools would I need to remove the ABS unit like you did?
Old Oct 12, 2005 | 11:50 PM
  #393
Bad as L's Avatar
Originally Posted by Suavy
shock would you snap a shot of how you plumbed every thing not using the ABS system?
Thank you,
Peace,
Suavy
I believe he already did that early on in this thread or the thread on NLOC...at any rate he did cover it well.
Dale
Old Oct 12, 2005 | 11:51 PM
  #394
ShockTherapy's Avatar
Originally Posted by Casey02L
...What parts/tools would I need to remove the ABS unit like you did?
A tubing cutter and flare tool, some brake line, and some fittings.
Old Oct 12, 2005 | 11:58 PM
  #395
Dale
Yes I did Dale.
Suavy, check out my pics on page 15 of this thread. If you have any questions at all don't hesitate to post up here or email me.
https://www.f150online.com/forums/sh...5&page=6&pp=15
Old Oct 13, 2005 | 10:56 AM
  #396
JavaBeans's Avatar
Damn Shock, I agree with your truck in so many ways.
Everything about it just looks right.
Old Oct 16, 2005 | 09:18 PM
  #397
pieerik's Avatar
A very nice setup, any new dyno numbers?
Old Oct 17, 2005 | 05:04 PM
  #398
jakhammer's Avatar
any dyno number to tell us yet?
Chris
Old Oct 19, 2005 | 01:35 AM
  #399
jlkastner's Avatar
I don't post on here a lot, I like to just read...but after seeing those pictures I am in SHOCK...Absolutly love your truck!!! The motor looks amazing and will perform unbelievably I'm sure. Can't get over how sick those two filters look either................WOW................
This is no doubt my favorite lightning PERIOD and im sure many agree.
Old Oct 27, 2005 | 10:36 AM
  #400
lurker's Avatar
Ttt
Old Oct 27, 2005 | 07:02 PM
  #401
CoCoCountyLbolt's Avatar
Can't wait till that beast is out tearin it up on the track!
Old Oct 29, 2005 | 01:10 AM
  #402
OK guys, 1st let me apologize for the lack of updates and responses lately. I spent soooo much time over the course of 4 months building this truck, I had to take a break, and needed to spend some time with the family. I also want to thank everyone that has had anything to do with this project. I couldn't start to list them all, but thanks to some local guys...Frank5L for the turbo inspiration and a few parts, rmfreeze for the generous use of his shop and wrenching on it with me at times, mhays26 for all his help, and all the other local guys that helped along the way. Also a huge thanks to everyone else (you know who you are) that helped out with information and even parts. I really appreciate it all.
That being said, on a whim I decided to put it on the dyno today. Ryan Allen was kind enough to write a few tunes for me, and I'm running the same one I drove to Lightning Fest on. It was close, took a little tweaking so we could smooth out the top of the graph, etc. Mind you this was all on pump gas, 15 degrees of timing, and ultimately 17psi, and a pretty much heat soaked engine. I think I made probably 16-17 pulls, and the last one had resulted in this.
685.3 RWHP / 673.3 tq
For those of you who like to see SAE, 662.8 / 651.2 were those numbers.
I am extremely happy with what it did today considering it hasn't been dyno tuned yet and was on pump gas. There's still a good bit left in it at the same psi once I can dyno tune it. And OMG, what a beast it is on the street. I should have a vid or 2 to post tomorrow evening, stay tuned.
Old Oct 29, 2005 | 01:26 AM
  #403
SVT F15O's Avatar
Quite impressive, truck is gonna make some sick power on a race tune and few more pounds of boost! Good job!!! -Mat-
Old Oct 29, 2005 | 09:40 AM
  #404
Silver-Bolt's Avatar
Looks great. How is the drivability on the street? About what rpm do the turbos spool up?
Old Oct 29, 2005 | 10:28 AM
  #405
rmfreeze's Avatar
I was a passenger with him BEFORE the tune was tweaked while we were testing out the stepper motor on the boost controller - looking for a gremlin. At just 7psi, it had enough to spin well through mid-2nd gear. When we found the gremlin, it started making boost. At 10psi, it was spinning at the top of 1st, through 2nd and into 3rd until he basically had to let out. It was one hell of a ride. I was grinning ear to ear and holding on. He needs some drag radials for sure but either way, he's going to go through tires. It's wild. I'm used to having instant boost and tire roasting power with the SC and then good pulling power as it winds up. Until he gets a converter in there, he'll have some delay for a sec and then the boost starts building quickly and the tires start spinning.
I took some vids of the first 3 dyno pulls that I'll give to Shawn later today.
