JLP Roll Cage Info?
Old Mar 9, 2005 | 07:47 PM
Suavy's Avatar
JLP Roll Cage Info?
Anyone running a JLP pre-bent roll cage?
I bought mine from JLP about 2 or 3 years ago and am finally getting around to installing it.
I was wondering if any of you would measure where the rear supports go in to the bed?
I also need the same info for the back window holes?
If anyone could help with this info I would deeply appreciate it.
Peace,
Suavy
Old Mar 9, 2005 | 07:56 PM
l-menace's Avatar
https://www.f150online.com/forums/sh...ight=rear+bars
There is a TON of information here. It Might be helpful
Old Mar 9, 2005 | 08:02 PM
fomocofan's Avatar
Those links do not answer any of his questions!
He is asking where to position the rear bars, as in specific measurements and or reference points!
Those links, if you read them, only refer to rear bars being requirred by IHRA/NHRA and that NO SPECIFIC angle is requirred!
Old Mar 9, 2005 | 08:06 PM
l-menace's Avatar
http://www.svtgalleries.net/gallery/...A_Roll_Bar.jpg
Pg. 8
I'm guessing it depends on the angle. From reading that post it appears that 30 degrees angle.
Originally posted by fomocofan
NO SPECIFIC angle is required!
I'm not trying to start anything . . .
Old Mar 9, 2005 | 08:09 PM
fomocofan's Avatar
Dude, #1 there is nothing in those rules about any angles.
#2 that is NOT his question.
He wants to know where to mount/drill holes, i.e. postion the bar in relation to the body/bed and rear window....the angle is irreleventt to his question or the rules for that matter!
Old Mar 9, 2005 | 08:14 PM
LatemodelRacer2's Avatar
If he drills holes in the bed in the same spot as a truck with a cage, and mounts the bed/body bar in the same place on the top cage bar, then the final angle should be very close to anyone elses L that has a cage in it.
my 0.02
Old Mar 9, 2005 | 08:17 PM
l-menace's Avatar
my 0.02
Correct, but he wants to know where to drill the holes...There is no question about angles here!
Everyone seems to be hung-up on the angle...it doesn't matter what angle it is...he wants to know where people locate the bar NOT the angle!
The angle does not matter to me, to him, or to IHRA/NHRA!!!
Gotcha!
Old Mar 9, 2005 | 08:18 PM
fomocofan's Avatar
Old Mar 9, 2005 | 08:22 PM
bglanden's Avatar
This is starting to sound like if the rear bars are required to me!
Just let Johnny get back from Bradenton and he can answer Suavy's questions.
No insult intended!
Bryan
Old Mar 9, 2005 | 08:27 PM
fomocofan's Avatar
Thats because the same wrong info was posted here!
30 degrees are not requirred and then he posts the rules claiming to show where it says 30 degrees and it doesn't...
But yet everyone still thinks that 30 degrees is a rule!
Like I said...That has nothing to do with this question anywayand I didn't bring it up!
Old Mar 9, 2005 | 08:32 PM
St Louis Lightning's Avatar
fomocofan - give it up bud! You may be right, but you sound more and more like an *** everytime you talk about this subject..
:o
Old Mar 9, 2005 | 08:36 PM
fomocofan's Avatar
I would rather be an A-hole and correct wrong info, than to have false info posted!
I really don't care what anyone on here thinks of me!
How is posting correct info, and thats all I am doing, being an AZZ??
Some yahoo posts irrelevent and wrong info on here, I correct him and I'm an Azz...
What F'ing country is this anyway??
Old Mar 9, 2005 | 08:46 PM
bglanden's Avatar
Fomco,
I don't think you're an axx, slightly abrasive maybe. I appreciate you're honesty, atleast I know you're not bs'ing.
Let this post get back to the original point, which I think only Johnny can answer??
Sincerely,
Bryan
Old Mar 9, 2005 | 09:17 PM
VINNIE's Avatar
All because 30 degrees is not stated. It is still a good number. So since it does not state what degree. why not use the 30 degrees as a starting point for his measurements.
Again I am not stating he has to use 30 degrees. Just , why not?.
Best of luck in whatever you do Suavy. I am very happy with my cage at whatever degree it is.
VINNIE
Old Mar 9, 2005 | 09:34 PM
fomocofan's Avatar
The question was where to place the bar not at what degree.
He, and rightly so, would like to know where on the bed to make the hole and where on the window to make the hole.
NOBODY cares what angle it is, nor does anybody know what angle that "everyones" bars are...the point is that the angle does not matter and should never have been brought up!
If he had asked at what angle should the bar be, I would understand this response, but he obviously is trying to avoid figuring the angles and simply wants a template of where to mount the bars!
I think what he was looking for was..
For example...
Rear bar hole in bed= 12" back from cab 6" in from bed side.
Rear window hole= 3" down from top, 6" in from side.
That type of thing...
The whole 30 degree thing has gotten way out of hand...
Apparently most of you don't even know what 30 degrees looks like, or you would realize that most rear bars are closer to 45 than 30!!!
