Say goodbye to oil in the IC...
Old Feb 7, 2004 | 09:54 PM
  #46
RED 92's Avatar
Originally posted by LightStruck
Sorry to butt in: I just thought of something, every time I drain my oil separator, it smells like it is about as much gas as it is oil....and real thin--like gas. Would you want that going back in oil system--or would it get burnt off with heat anyway.....or ??? what am I not thinking about here?
Yes, I would not dump the oil trapped in the separator back into the engine, granted it came from there but it is dirty and we do change the oil...... I havent smelled the gas smell but maybe someone else has.....
Old Feb 7, 2004 | 10:35 PM
  #47
JeffsLightning's Avatar
Originally posted by RED 92
if you cant answer questions I must assume you dont have a clue..and are only interested in selling your Kit ..I wont buy your kit now that I realize you dont understand the 5.4 supercharged PCV. Good Luck selling it here. Go back to NLOC and sell it .....
Your attitude in this thread has probably caused more People on F150online to doubt your expensive kit.
[/B]
Rich you have not answered my question... You know the pressurized inlet boot...I'm just trying to understand also and it seems to me Vince has a handle on it... What kind of automotive background do you have? Have you ever tried a seperator off of the stock pcv location? We need to get that oil sucking problem fixed. I have tried numerous remedies ever since the first time I pulled my blower to check/clean my IC. I don't like not having vacuum under boost and I certainly don't like smelly breathers. I also hate dumping my air compressor type seperators every time I turn around...not to mention I think some oil is getting by them...As you can tell I like this new oil removal setup but that's me.. Everyone will make up their own mind as to what makes sense to them and they will act accordingly...Jeff
Old Feb 9, 2004 | 07:57 AM
  #48
tom vandiver's Avatar
Smile
I purchased Vince's system about a week ago. I have known Vince for about a year. He did the install of the N2O system on my
'99L. I like not having to empty anything like some of the other systems and expect zero problems from Vince's product.
Old Feb 24, 2004 | 10:21 PM
  #49
LtngRod01
Guest
Posts: n/a
Maybe a dumb question?
I read all the back and forth about the Oil seperator and PCV valves. Seem like this kit or system is a good idea, but my question is, has anyone talked to the SVT Folks to determine if a certain amout of oil is engineered to go into the intake? This question may sound dumb, but hopefully the Ford SVT engineers considered this oil problem. I have fiddled with a lot of old Ford engines, some actually needed a little oil in the combustion chamber to ensure extended engine life. Remember Ford must consider durability and not short term performance.
The Ford Harley Davison Truck Club has a complete set of pictures and part numbers to put an oil seperator on the 5.4 Supercharged engine. Basically same engine as Lightning, just detuned a little.
Marty
Old Feb 25, 2004 | 03:58 PM
  #50
Here is an update to my oil seperator mod.. I and some people do not like blocking off any of the hoses. I installed 7 dollar booster check valve in the lower line so I do not blow boost backwards out of the lower intake hose....Here is a pic. of the new setup...
Old Mar 18, 2004 | 07:14 PM
  #51
alexr40's Avatar
Can I Capp / plug the ...
Can i Capp / Plug / clog the lower intake line that goes to the Intake manifold? and just have an oil separator from the valve cover to the plenum? without the 'T'?
please advise
Old Mar 18, 2004 | 10:31 PM
  #52
usahooters's Avatar
Jeff just what do you mean by
Old Mar 19, 2004 | 06:59 AM
  #53
The lower pcv hose that goes to the back of the intake normally pulls vacuum but under boost blows backwards towards the pcv and the upper plenum (TB spacer as Ford calls it). With the check valve located in that line no reverse flow can happen. Sort of like guys using a dime to block off the top line but I did not want to block any of the factory lines with this seperator.
Old Mar 19, 2004 | 10:20 AM
  #54
usahooters's Avatar
Cool Kinda like this set up I've been using since April of 2001.
Click on the pics that say PCV
https://www.f150online.com/galleries...w.cfm?num=4257
Old Mar 19, 2004 | 10:53 AM
  #55
Fordsrus's Avatar
usahooters
Where can I get one of these aircraft values at. Any part numbers and the manufacture name?
Ryan
Old Mar 19, 2004 | 11:34 AM
  #56
tallimeca's Avatar
oil
I am 100 percent positive the oil on my truck is comming through one of the lines that connects to the intake boot. Also, as the oil builds up, the quality of my idle goes down. Clean out the throttle body housing and blade and the idle smooths out enough that it's noticable. Some oil may be coming through the top pcv line but the majority is ABSOLUTELY coming through the intake boot itself.
Old Mar 19, 2004 | 05:42 PM
  #57
usahooters's Avatar
Your correct tallimeca, look at my gallery pics and it shows you how it gets there.
Old Mar 19, 2004 | 06:26 PM
  #58
usahooters's Avatar
Ryan I'll get you a name and part number........
I want you all to know this mod is only going to stop oil from getting in your intake boot and throttle body area, it does absolutely nothing for the oil problem in the intercooler area.
My TB is clean as a whistle and has been since day one. I installed this same check valve on my new 04 the day I brought it home.
Old Mar 20, 2004 | 08:11 PM
  #59
usahooters's Avatar
Ryan I will email you the info tomorrow night when I get in from work.
Old Mar 20, 2004 | 11:06 PM
  #60
Fordsrus's Avatar
E-mail Project600@aol.com
Ryan
