Boost bypass???
Old Sep 28, 2003 | 01:08 PM
red99svt's Avatar
Boost bypass???
Boost Bypass..Ok is this a good or bad idea to do...
Old Sep 28, 2003 | 01:17 PM
Rob_02Lightning's Avatar
It's a Must
Here's your two choices
Either just unplug it,
Or do by re-routing the Vac (thats how I did mine)
Old Sep 28, 2003 | 01:24 PM
All you need is a small Vac tee
Simply unplug the pink line from it's original spot.
Then put a little screw in the place it WAS plug into.
Then locate the other line, AND THE FACTORY SPLICE,
Simply relace splice with a Tee, and put the Pink line there.
ALL DONE
red99svt's Avatar
unplug
just unplug it and leave it unpluged thats it???Dont have to cap it or anything??
Old Sep 28, 2003 | 03:06 PM
YEP
Just unplug it and have fun
Old Sep 28, 2003 | 03:22 PM
Probleminfected's Avatar
or just get a chip from PSP that does it through the pcm
Old Sep 28, 2003 | 04:04 PM
red99svt's Avatar
boost
Cool i know the stock boost is 8psi well im hittin almost 10 now after takin that piece out..
Old Sep 28, 2003 | 04:28 PM
light03's Avatar
Question: Why didn't ford want the lightning to go past 8lb's? is it really safe to have that much boost?
Old Sep 28, 2003 | 04:37 PM
bigdaddy's L's Avatar
good pics here
http://www.rpmoutlet.com/boost%20bypass.htm
Old Sep 28, 2003 | 04:58 PM
TiresWinRaces's Avatar
The Eaton's are most efficient up to 8psi (many on this board will disagree with this). Adding more boost will make more power, but the heat efficiency declines as boost increases.
BTW, the boost bypass has no effect on total boost. It just prevents dumping boost during shifts. That's it.
Old Sep 28, 2003 | 05:03 PM
light03's Avatar
Nice! Thank you for the reply TWR!
Old Sep 28, 2003 | 06:22 PM
ShaneMcKenna203's Avatar
I've had mine unplugged for months now. What exactly did I do by unplugging the boost bypass? Someone said I dont dump boost between shifts, is that all? Why does it come like it does, and how can we get away with bypassing the bypass?
Shane
Old Sep 28, 2003 | 06:26 PM
swiseuf's Avatar
it pulls boost off during shifts to save the stress on the tranny
Old Sep 28, 2003 | 07:02 PM
macracer18's Avatar
hello all my L is stock will it be ok if i just unplug the boost bypass i just want to make sure it won't hurt anything
Old Sep 28, 2003 | 07:25 PM
LIGHTNINROD's Avatar
I did a 'search' and here is all the info you need . Be sure you read all of Lightningtuner's posts, especially on pg. 2.
Dan
