4# Pulley worth anything...
Old Sep 12, 2003 | 07:10 PM
Nightrider's Avatar
Question 4# Pulley worth anything...
Is just a 4# pulley worth any HP or TQ and if so any figures on how much? Not a chipped truck but an otherwise stock truck. Thanks.
Old Sep 12, 2003 | 07:17 PM
Unoid's Avatar
I'd grant is about 80% as much as it would give to a chip and filtered truck.
most people would advise you to get a chip for 4+ also.
Old Sep 12, 2003 | 07:29 PM
cpeapea's Avatar
4lb= lots of seat in the pants performance!!!
Old Sep 12, 2003 | 07:52 PM
hslightnin's Avatar
i got a 4#'er on there and no chip stock plugs and its a fairly ez install with the right tools
Old Sep 13, 2003 | 12:28 AM
MoparMike's Avatar
Is a 6# lower and a 2# upper too much for a 2000 L with stock motor?
Old Sep 13, 2003 | 12:47 AM
Don's Bolt's Avatar
Yes and No
If you have a proper tune, and take the proper precautions you will be OK.
Tonight at my local track is a good example of what i mean. A 2002 blew his motor up about halfway down the track. It was a cool night in the 50's and I doubt he any race fuel in his truck. While all the other Lightnings made sure they had race fuel in there trucks and all ran great.
I bet it will be the same this year as last year and the year before. You don't hear about blown motors in the summer. Now that it is getting cooler, and when it gets real cold, you hear about tons of engines blowing up.
When you run 6 or more LBS of boost you have to make sure you have safe air fuel ratios, and especially when it is cool out make sure you have 104 octane race fuel in your truck. When it is cool the air is more dense making your truck run leaner, also the computer will add timing when it is cool. Those two things can be a bad combination with 93 or lower octane fuel.
You can get away with this a little easier when it is hot out, you will be richer, due to the thinner air, and the computer will take timing out when it is hot.
It is all about knowing your truck the conditions you are running in, and what you can do to make it as safe as possible.
I see you are new to the boards, so in your case I might sugest starting out with just a 4 or 6# lower, and learn about these trucks. When you learn more about what the L needs, then maybee go up a few lbs of boost. Thats what I did, I started out with 4 lbs of boost the first year. the 2nd I upped the boost and my mods/ Now on my 3rd year with my truck, I went nuts with the mods and the boost.
Hope that helps
Don
Old Sep 13, 2003 | 01:02 AM
MoparMike's Avatar
Thanx Don.Im with ya on the 4#.Just curious because someone was selling one with the 6#,2# setup.Sounded overkill to me.
Old Sep 13, 2003 | 03:58 AM
whtltg's Avatar
Agree with Don!!!! However I ran a 4# lower with a 2# upper on stock motor, b/4 having a Jerry W dyno tune. Love this set-up. Course now is not the case, because have moded much more since then!
Old Sep 13, 2003 | 09:23 AM
Rob_02Lightning's Avatar
Don
I was just talking about that on another Forum
I pray with the gained knowledge, people tune safer this winter
Me I back down my boost 2lbs in the winter (remove the upper)
but continue to use the same tune, (making it richer and safer)
Run 2 Zones Colder Plugs (cooler cylinder temps)
and as Don Stated, will use Race Fuel due to the colder Temps
Lets hope this yr is better than last
Old Sep 13, 2003 | 09:59 AM
HEVYRESQ's Avatar
Spend $2000 on beater 4x4 for winter....its much cheaper than building a new block
Old Sep 13, 2003 | 02:46 PM
LightninSVT's Avatar
Where do you guys get race fuel from? I put 94 octane in mine, is this not enough if I was to take it to the track when it gets colder??
Jon
Old Sep 13, 2003 | 06:06 PM
denny0328's Avatar
Don,
do you think that just a 6# lower is ok with a otherwose stock motor? im looking to chip mine too, and im thinking that the 6# is only $20 more that the 4#. what do you think?
