600hp plus guys here please…
Originally posted by LightningTuner
Randy Haywood runs them in his 1800 hp Outlaw car. I run 24 psi with spray on top, and he runs close to 40 psi.
Cmom Sal lets keep it real
Joe,
Will those injectors work for our application?
What valve train are you big boost guys running? I found several threads on the Corral about broken ModMax valve springs, but I am told this is due to improper installation.
Is there a proven valve train other than ModMax?
Randy haywood may not make 1800hp but he does have a legal 7second mod motor super street outlaw car , and if they work in his car I,m sure the amount of boost that we push is not going to hurt .
lightning tuner
With such tremendous boost levels, @ 24#, I have a hard time believing that the stock head gakets hold up....there must be a secret done in the sealing...I wonder how Sal is installing his head gakets...??
Originally posted by Ayrton
Joe,
Joe,
--Joe
The injectors on our trucks are 14ohm, they are also called high impedence. You can purchase a injector driver box that allows you to use a low impedence injector, but those have been known to give problems. The highest high impedence injector Ive seen used on any Ford Product has been a 55#.
Hope this helps
Hope this helps
I thought it was the other way around…
I thought we had 42# high impedance injectors and we had to stick with highs…?
