What are my options for upper pulleys if I already have a 4# lower...
I've got a 4# lower and I love it. I just want to get a little deeper into the 12's. Since I ran last time I picked up a set of traction bars and et streets, so that should help with about a 10th or so. My 60 foot times on stock tires were 1.85-1.95 all day long. I want to run a 1.75 60 foot on these et streets, I should right?
Also b4 I get to the track I will have electric fans, cobra water pump, and hopefully my intake from jdm with a 90mm mass air on.
Even with all that, I don't see my times going down from a 12.64 that much. The tires will help a lot, but I am wanting a little more boost. I can swap my 4#er out for a 6# pulley and call it a day. But I already have the 4 on and I really like it, so what are my options as far as upper pulleys? I know there are 2.75 and 3 inch pulleys... Can I get more info on whats safe with a 4# lower..
I need to figure out what I want... Weather it be to be more into the 12's or If i want to run an 11...
Say I want to run an 11, and off nitrous what are my options?
Swap the 4# and get a 6 and go from there.... Or keep the 4#er and get an upper. thanks, Shane
I run a 4lb lower and a 2lb upper
I love that combo.
I happen to like the quick change upper, it takes maybe 2 minutes to do if you take your time (1 minute if you rush)
Got mine here from South Florida Pulley Headquarters
http://www.southfloridapulleyhq.com/frame.htm
but Johnny has a nice new set up thats very reasonable
if your gonna keep it on all the time
http://johnnylightningperf.com/newca...p?intProdID=62
I love that combo.
Rob what are your times with your mods off nitrous. That combo sounds great for me as long as im not hurting that blower... I know any pulley bigger than stock is hurting the blower, but I took the jump to a 4#er and I'm comforterble there, what will the 2lb upper do for me and to the blower? How much boost will i put out then? Currently I am running between 12-14#'s. I am more than happy with a 12.6 but want to get that down if I can. Thanks, Shane
i just spoke with Paul at Razor's Edge (great guy) and he has the interchangable upper pulley combo for $215. It's a 2.77 and a 2.84. The smaller pulley putting out 2-3 more pounds of boost, the bigger only 1 or 2...
Now I am thinking thats to much boost for the stock blower. With my 4# lower, chip and filter I put out 12#'s of boost on a warm day. 13-14 I've seen on a cold day. With the program I have on my chip I dont WOT a lot in the cold so I dont see 13-14 any more... But even with the 12#'s I have, ad 1-3 #'s (upper) on top of that and I'm at 13-15#'s... Thats a lota boost and a lota heat. It is a 2000 so the rods are a litte stronger, but still that blower creates a lota heat at that much boost. What can you all reccomend for me with a stock block and a stock blower? Thanks, Shane
Dont worry about a 4 and any upper being to much boost for the stock blower.
I remember seeing JL's truck have a 8lber and 2-3upper back in late 2001.
I ran a 6lb lower for over 23,000 miles and my stock blower looked BRAND new.
I wouldnt even mess with the top pulley unless you want to have it interchangable.
Personally, I would leave the 4lber, get a 75 shot for the days you want to go fast. The Blowers LOVE alittle Cooling NOS in front of them....
I've thought about nitrous... I think about it every day. But i want to try to get the most out of my truck (without blowing it up) THEN nitrous. I have heard great things about our trucks and a 50-75 shot... Is that what's best for me is a 75 wet shot of NOS
I can do...
4# lower + 75 shot nitrous
swap 4# and get 6# lower
4# lower and 2-3# upper....
hmmm nitrous sounds good, but I don't know much about nos. I'm learning more and more about our trucks, and how our blower works and what it can handle... So I wanted to just up the boost a little. But isn't shooting a 50 shot the same as putting a 4# pulley on there.... Or is it safe to say tuned right, the nitrous is safer?
I can do...
Originally posted by ShaneMcKenna203
Rob how much were the pulleys from South Florida Pulley Headquarters
Rob what are your times with your mods off nitrous. Currently I am running between 12-14#'s. I am more than happy with a 12.6 but want to get that down if I can. Thanks, Shane
(2) 12.0's, (1) 12.2, + (1)12.3 with the Juice ""and same set up"".
AS far as the extra Upper Pulley, believe it or not I run better
AND FASTER times with the 4lb than 6, GO FIGURE ????
I know it's because I don't let it cool down. It's too much heat, and over spinning the S/C. Soon I'll make some 6 lb all gas runs with more timing, I may even let it cool down for once.
Originally posted by Rob_02Lightning
Price: $219.95 shipped!!
Shane, Bad example comparing mine right now, I have new Chip programs this yr with too low of timing and can only go 12.7's on Filter, Chip, N 4lb Pulley.
I hear about L owners wanting to get the most out of their trucks before turning to NOS. However isn't the 4#er usually the crossroads of continuing our performance mods with NOS in mind or without? I believe MM&FF mag said, anything above 16# of boost, we should be using 98 or higher octane.
