Head Porting Question?
Old Jan 21, 2003 | 08:08 PM
collins8's Avatar
Banned
Question Head Porting Question?
Got my heads over to the guy doing the porting work and we have a question. He feels like the swirl dam on the combustion side of the intake valve needs to come off. I have been told that it directs the air charge down to the center of the piston and you should grind it off. Have any of you guys got any info on this?? Obviously taking it down may improve intake flow but it was put there for a reason by Ford??
Rob
Old Jan 21, 2003 | 10:26 PM
Bad as L's Avatar
Rob
your right it is there for a reason, but I will also point out that ford made a revision of that dam between the 99/00 heads and the 01/03 heads. The newer heads have a smaller dam in the combustion chamber (01' and up) also have a different part number, a different combustion chamber, the intake valve has been moved and also the finish around the valve seats is better on the newer heads. The valve doesn't sit down in a pocket with a big lip around it. Makes for better low lift flow.
Most of this info you will find in the latest MM&FF with pictures the rest of it I remember from somewhere else.
Dale
Old Jan 21, 2003 | 10:50 PM
Turbobo's Avatar
Good Info, never knew there was a change to the later model "L" head.
So if we can get the improved '01 and up style head with the new thread count on the 12/02 and later produced heads we all be set!
Old Jan 22, 2003 | 12:31 AM
Jay Lincoln's Avatar
Exhaust, exhaust, exhaust.
If you are having the heads done. Spend your money on the exhaust side of the motor. Larger gains will be found there. If you can afford it, put in the largest exhaust valve in you can fit.
Have the porter work on the exhaust port. Intake flow is secondary on a blower motor. More intake flow is just a pulley away.
Old Jan 22, 2003 | 01:24 AM
NCETRY's Avatar
Well if you want a good port job talk to Tim or Paul at REM. I got some info on there heads today it's impressive. I can not give out any numbers but there is big gains on the intake and exhaust. I can not wait to get these heads hooked up to a Works 140 spinning up 30 psi should be insain
Old Jan 22, 2003 | 04:11 AM
Bad as L's Avatar
I gotta ask.....why in the hell are their (REM's) flow numbers confidential ?? That doesn't make any sense.
Dale
Old Jan 22, 2003 | 09:00 AM
JohnnyLightning's Avatar
"Why are rems Numbers confidential?" You must not know alot about them.. "Everything (they) do is much Better than anything anybody else does.. They'll even send you private e-mails under cutting Your tuners prices and abilities too! We here @ JLP have received Numerous Complaints about there Tactics! We just got another 1 yesterday..We here @ JLP have no problems with these *New* shops trying to get in on the Lightning market,but when this is their way of doing it we then have a problem! And i'm sure the other companies that have been in this buisness as long as we have agree!...We here @ JLP have been Porting heads and have been running them for a year to show on the *Track* how well they work. and trust me i have run against many other trucks with their own head work design and we have done very well. You can give us a call for moe info. we'll be glad to talk about it.....JLP
Old Jan 22, 2003 | 09:06 AM
VINNIE's Avatar
Old Jan 22, 2003 | 09:23 AM
superfords's Avatar
confidential?
did they not give you flow numbers? or did they provide numbers and then swear you to secrecy?
sounds fishy to me.
I wouldn't spend a couple of grand on heads without some numbers. just my .02.
later,
chris
Old Jan 22, 2003 | 09:52 AM
Fast Gator's Avatar
Old Jan 22, 2003 | 11:37 AM
captainoblivious's Avatar
Seriously.
Old Jan 22, 2003 | 12:14 PM
collins8's Avatar
Banned
Thanks for the Info!!
The guy porting my heads feels like he can definitely do them some good. When I get some flow numbers I will post them.
I have already invested in the larger Ferra intake and Exhaust valves. I am debating whether to change cams. I have had several reputable people tell me I will see no gains unless I go with a little more agressive cam.
If any one is interested the guy that is porting my heads is located near the Knoxville, TN area and he has a very good reputation with the local crowd for doing good work. He is presently doing some 4V head work for Robert Hindman, Fun Ford Mod motor champion, and he built the motor and ported the heads for Gene Hindman, NMRA Pure street record holder, 10.72. If anyone would like to get some contact info let me know.
Old Jan 22, 2003 | 12:32 PM
easterisland's Avatar
The guy who ported my heads said that you shouldn't take it out. He did remove a little material on the back side of it. For what that is worth.
www.mohrperformance.com
I deal with Chris
Old Jan 22, 2003 | 12:57 PM
VinniePSVT's Avatar
I smell a fight brewing...
Old Jan 22, 2003 | 03:36 PM
unclemole's Avatar
Thumbs down
"Why are rems Numbers confidential?" You must not know alot about them.. "Everything (they) do is much Better than anything anybody else does.. They'll even send you private e-mails under cutting Your tuners prices and abilities too! We here @ JLP have received Numerous Complaints about there Tactics! We just got another 1 yesterday..We here @ JLP have no problems with these *New* shops trying to get in on the Lightning market,but when this is their way of doing it we then have a problem! .....JLP
Call the waaaaaaaaahmbulance for JLP! You sound just like a jealous woman who can't stand the competition.
