Dent in stearing wheel cover
(I posted this over in the body care forum, but that place appears to be a ghosttown. Perhaps some of my KR brethren can help?)
Somehow, and I, frankly, have no idea, I have a dent in the Ford emblem in my stearing wheel cover. Does anyone know if its safe to pop the cover off and try to pry the dent out? It seems like I could get the dent out but I'm a bit weary about taking off the stearing wheel cover. Has anyone done this? If so, what do I need to do.
Thanks in advance.
Thanks in advance.
I would tread VERY lightly in the area you are talking about. The air bag is directly underneath (if I understand what you're referring to) and you do not want to screw anything up with that. As far as I know the cover comes in an assembly with the airbag attached underneath. You might just want to talk to your dealer on this one and get his opinion. Maybe have HIM try to remove the Ford emblem and if he screws it up then its on him to fix it. Just my $.02 worth.
IL6fan
IL6fan
Ouch. That's a toughy.
Isn't that just a sticker?... I mean, I don't have one on my truck as it's a 2001 but, the ones that I've seen appear to be a simple sticker. Any thoughts?
RP
RP
No, RP, its not a sticker, its like a solid piece of plastic or aluminum. Enough to dent it. I'll try to snap a photo of it that y'all can see. IL6, thanks for that piece of advice. That's all I need to do is ignite the airbag. Its a very small deal, just frustrating because I have no idea out it happened.
Esquire I understand the "small deal" comment, but if you're like most of on here its those small things that bug ya the most. Sounds like that is the case. I feel for ya man, i would be the same way. Good luck and let us know what you end up doing.
Gotcha Esquire. That was just a misconception of mine... sorry about that.
I'm not sure what to tell you and, like IL6 mentioned, it's always the smallest of small items that drive me batty. (take for instance my rear power sliding window switch being mounted slightly crooked when I installed it the first time... ended up buying a dash piece to make it look right...).
I'd drop Torrie at fordpartsnetwork.com a line and see what he can get you a cover for... torrie@fordpartsnetwork.com . Tell him RP sent ya...
Good luck and let us know what you do bud...
-RP
-RP
Originally posted by MikeF150
Esquire - there is a "How to" in the latest issue of FTW (Ford Truck World) Magazine regarding removal of the steering wheel in late model F150's and Expeditions..... there's two plastic plugs on the back of the wheel you need to remove and then remove the exposed nuts. The cover of the wheel should then come off w/o messing around with the airbag.
As an extra precaution, you should probably disconnect your battery and then turn on your headlights to drain any residual electricity as the airbag is electrically triggered.
You can probably find the FTW mag at a newstand if you don't already subscribe. Appears to be an easy fix.
