Dash Lighting possible to change?
Old Mar 19, 2006 | 10:39 PM
ws6_guyscrew's Avatar
I was just wondering is it possible to change the color of the dash lights? Stock trucks got green, but I was wondering if I could change mine to blue.
Old Mar 20, 2006 | 02:08 AM
SSCULLY's Avatar
The stock bulbs are white, and the green tint is from the gauge overlay.
Unless you go with an Indigo blue overlay, changing the color is going to half @ss at best.
Say you try to put in a blue blub, and then the blue shines through a green overlay. Not going to turn out so well.
If you do a search here, you will find a few that changed out the guage overlay in the same range of MY rigs as yours.
Good Luck
Old Mar 21, 2006 | 10:12 PM
hmm thanks for the info. I guess my whole dash is good green anyways lol. When I get gauges it will be NuImages whiteface with blue flames ( same on A/C panel ) & put a black bezel in, should look good.
Old Mar 21, 2006 | 10:25 PM
Dizzead's Avatar
Scully's right. You could buy a blue bulb and a white gauge overlay, that might work. Search F150 overlay on ebay, they have different colors
Old Jun 8, 2008 | 07:57 AM
Kryptonite.'s Avatar
What do you think about this overlay? I got it from streetbeatcustoms... for $69
Old Jun 23, 2008 | 08:38 AM
Les22's Avatar
Bump...
Krypt- how tough is the job of changing out the stock dash overlay? What do you have to remove to get at the original overlay?
Old Jun 24, 2008 | 12:19 PM
scott.joyner24's Avatar
not that hard to do.
Old Jun 27, 2008 | 07:18 PM
minimonster17's Avatar
you will need some small torx bits though to get the cluster apart once you have it pulled out
Old Jun 27, 2008 | 09:08 PM
TapptOut's Avatar
I bought one similiar to that one on ebay, and i took off my whole dash and everything but than you have to remove the gague needles, and i called a local shop and it was 115 bucks to re-calibrate everything. Which sucks. Anybody know a cheaper way to get the gaguges calibrated?
Old Jul 6, 2008 | 02:23 AM
1clean42's Avatar
when i changed mine on my truck, i let the truck sit and idle for about 5 minutes to get the temp needles up away from the cold area, then took a picture of where the needle sat...same thing with the tachometer. the speedometer, i really just had to guess at; i had my dad drive alongside me and then i just stuck the needle on while driving lol also take pics of your gas gauge to keep it accurate.
