Keys hitting the dash
Old Nov 26, 1999 | 08:40 PM
cabraco's Avatar
Post
Check with your dealer, they offer a short key option........................
Old Dec 12, 1999 | 09:53 AM
steelwheels's Avatar
Exclamation
Beware of too many keys hanging from your ignition. The weight my cause abuse of the tumbler system.
Old Jan 7, 2000 | 01:17 AM
bazil1's Avatar
Post
okay, boyz....(& gurls).. my snap apart key ring device is a 1/4 drive swivel socket adaptor from snap-on, with the pin & centre piece removed.
You now have two little "ends" with a hole for the rings, and they fit together using the female & male parts of the 1/4 drive. I've had this thing for ten years, and the keys wiegh lots, it dangles from my wheel, ( I KNOW )and never has fallen apart yet. It was expensive, but was a gift for spending LOTS from the snap-on dealer. the key here, (no pun intended) is use a good quality swivel, if ya wanna make one.
Old Jan 20, 2000 | 10:50 PM
true_blue's Avatar
Post
My key chain hits too. I am in the Navy, so like all sailors, I have a huge brass clip that I hang my keys from. It makes a pretty good gong as I go over tracks and big bumps. It is a real no brainer that I need to seperate my keys, but I would have never thought that as many people were as lazy as me (no offense).
Take care, and keep on Truck'n
97 Metalic Blue F150 Xtra cab, Flare side, 700 Watt Sony CD system, Hard cover, Customized air box, running boards. Planing on lowering, chipping, and adding a Cat-back.
Old Jan 24, 2000 | 08:59 PM
bosch45's Avatar
Post
My solution was a valet key ring, they sell them at any hardware store. it has 2 rings,
one on each end, and one side detaches,so you
can put the ford key on one side and everything else on the other.
2000 F150 XLT BLACK, 4X4,SPORT 5.4, 3.55,
SC,SB,ABS, 17IN WHLS, REMOTE ENTRY, CD,
TUBULAR SIDE STEPS, SMK BUG GAURD, VENTSHADES, MOLDED MUD FLAPS, LINER ALL FORD PRODUCTS
Old Feb 17, 2000 | 04:50 PM
Claudia's Avatar
Post
Of course, you COULD always do the following:
Press hard - and GO LEFT!
2000 F150 XLT S/C, V6, 5 Speed (Is there any other way?!) Power everything, CD, Capt chrs, 3.55 axle, etc...
Old Feb 18, 2000 | 01:07 PM
J-C's Avatar
J-C
Cool
I opted for the valet key-ring. Now all my trailer keys are on one ring and the truck key's on the other. Worked for me.
I tried the "press hard - go left" trick but eventually had to stop going left and then the problem was back...
Old Feb 18, 2000 | 08:05 PM
insect2's Avatar
Post
Get a small magnet like to hang stuff off the refrigrator door. Paint it black or gray like your dash. Glue it next to where the keys hit the dash. When you get in and start up just place the loose keys on the magnet to stay put.
Old Feb 21, 2000 | 07:23 PM
J-C's Avatar
J-C
Post
My keys are brass and won't stick to the magnet
Good idea for someone with steel or nickel keys, though
Old Mar 17, 2000 | 05:21 PM
roden's Avatar
Post
I had the same problem. A week after I bought my truck, I put a strip of gray adhesive foam on the spot where the keys hit and now... complete silence.
Old Mar 17, 2000 | 09:26 PM
ps398's Avatar
Post
I got an extra key made for my 97 and put it on a key ring by itself and use it in the ignition.
