2001 f150 headlights
Old May 3, 2018 | 06:10 AM
jimbo74's Avatar
5 Year Member
are the 4 piece headlights compatible?
Old May 3, 2018 | 09:31 AM
Yes they will work.
Old May 3, 2018 | 03:54 PM
jimbo74's Avatar
5 Year Member
sweet, I picked up a set of 4 pc units in black, to repalce the ones I have now. The ones I have now are aftermarket, with halos and leds in them, but the halos don't work, nor do half the leds.
Old May 5, 2018 | 12:52 PM
jimbo74's Avatar
5 Year Member
ok, so my new 4 piece lights, I can't get to align for beans, there is over a 1/2" gap between the pieces, and it looks horrible. not sure what to do at this point?
EDIT: I may need to try and look up some youtube videos or something, I really can't figure out how to get those clips in place on their tracks and have the long screws pass through the holes at the same time
maybe there isn't anything wrong with my new headlight housings.....
also, is there a relay I can replace to get rid of the hyper flash of my LED turn signals? or do I need to try and add a resistor to the system at the light?
Old May 5, 2018 | 07:04 PM
Take a look:
Amazon Amazon
Old May 5, 2018 | 08:46 PM
jimbo74's Avatar
5 Year Member
Thank you for the link. Ha, I swear you are the only person still alive on this forum!
glad to know it is a flasher relay, like my motorcycle. On my lancer, there is no flasher, it's computer controlled, so I just deal with the hyperflash
I might look at getting a slyvania silverstar corner bulb in a 3157 though instead
The 3157 led bulb I got, doesn't appear to be a dual filament, so more like a 3156
Old May 7, 2018 | 01:39 AM
SLW-SVT's Avatar
TRUCK OF THE YEAR - 2011
I'm using these on both of my trucks: https://www.theretrofitsource.com/le...-x-vf-led.html
Old May 27, 2018 | 07:23 AM
jimbo74's Avatar
5 Year Member
Actually found what I was looking for.... should be a pretty good setup when I am done. I will post pics later on
Old May 28, 2018 | 10:36 PM
JobsBoy's Avatar
Show some pics here,Looking forward!
Old May 29, 2018 | 12:23 AM
jimbo74's Avatar
5 Year Member
I will. Just the lights I ended up going with was a set, and the corners sucked (one actually fell out about an hour ago), so I got different corner lamps that also have no yellow reflector. I also found some switching LED lights, they are white always on, and yellow when the signal or hazards is on
also doing a billet grill and a chrome header shell
Old May 29, 2018 | 11:40 AM
Got some pictures to show us?
Old May 29, 2018 | 11:41 AM
jimbo74's Avatar
5 Year Member
Not yet. It's on the low priority list right now.
I have an truck day planned tomorrow with higher priority items
Old May 29, 2018 | 11:45 AM
Aww, the suspense....
Old May 29, 2018 | 01:16 PM
jimbo74's Avatar
5 Year Member
Ok, so this took me over an hour, and I still have to put my dash back together.... the new relay is larger than oe, and thus, won't allow the cover of the little box back on. Oh well. The new relay works, no more hyperflash!!!!! Just had to take apart half the dash! It is located above the obd2 port all up in there. You actually can't remove the way it is mounted, well at least not without quite a bit more work.
and my new lights are sweet. Amber turns, and white the rest of the time when parking lights are on.
here are my new corner lamps and headlights. All black insides, with clear lenses.
I am running some LED headlight bulbs I bought as well
better pics may come tonight when you can actually see them
Setup:
Gap :
Corner with bulb off:
white corner:
yellow corner:
Old May 29, 2018 | 01:22 PM
Wow!!! They look awesome!! Good job!
