Questions about retrofits
1. Can you buy F-150 heads already retrofitted?
2. Does retrofitting void any warranties?
3. Can anyone reccomend anywhere near Hamilton ON, Canada to have them installed?
Last,
4. How long does an install usually take?
Last,
http://www.projectoretrofits.com/
Plug and play most likely. Install yourself. Probably hr at the most.
1. Can you buy F-150 heads already retrofitted?YES
2. Does retrofitting void any warranties?ONLY IF SOMETHING GETS WIRED WRONG AND IS THE CAUSE
3. Can anyone reccomend anywhere near Hamilton ON, Canada to have them installed?NOPE I CAN'T...ORDER THEM COMPLETE AND INSTALL YERSELF
Last,
4. How long does an install usually take?COMPLETED ASSMBLIES WITH THE WIRING HARNESS ADAPTER PIGTAIL...APPROX AN HOUR
Last,
if you can change a headlight bulb you can install completed retrofitted assemblies..the basic ones..as long as they don't have the fancy add on lights....
pm TuxedoBlack
Oem ones are 1100-1400 still...unless you find some on eBay
I spent about 250 on my retro not counting the headlight assembly.
