HID trouble shoot : Fogs on=Lights off
Old Aug 26, 2011 | 10:16 PM
MedicF150's Avatar
Disregard.. I just pulled the fuse cover off and relay # 203 had come off completely. I put it in and she fired right up !! Now back to my dumb hi/lo prob... I rather get another kit the plugs in properly before I hack into the OE harness..
Old Aug 26, 2011 | 11:49 PM
Raptor05121's Avatar
Bingo.
Old Aug 27, 2011 | 12:11 AM
MedicF150's Avatar
heres a link to the ddm H13 kit I have. This shows you the green plug im talking about with great pics and detail.
https://www.ddmtuning.com/support/in...loaditemid=102
Old Aug 27, 2011 | 12:20 AM
Okay. So the green plug is the OEM plug. Gotcha.
Yes the OEM plug is a signal wire. If the harness/relay is not getting 12v from the high beam wire, then your high beams will not work. Since you know that plug isn't in right, I would DEFINATELY suspect that. You can try pushing really hard, or you can very carefully take the prongs out of the DDM side of the connector and push them in the green plug manually by hand. Lastly just cut both plugs off (leaving space on both ends if you want to reattach them later)and hard-wire them in place.
Other than that, check your high-beam fuses. But you've got a 99% chance its that plug.
Old Aug 27, 2011 | 12:24 AM
MedicF150's Avatar
thanks bro! I think Im going to look at the plug with more detail tommorow and see why it is that its not going in all the way. I'll keep you posted .. Thanks again !!
Old Aug 27, 2011 | 02:46 AM
Anytime.
-Alex
Old Aug 27, 2011 | 08:14 AM
08SILVERFX4's Avatar
if you dont have the dual beam kit, dont flick your high beams on and your lights wont go out...problem solved...
Old Aug 28, 2011 | 10:34 AM
poolboy1191's Avatar
He has a Hi/low kit.
But my OEM plug was grey... I wander what the difference is??
Old Aug 28, 2011 | 09:13 PM
MedicF150's Avatar
First things first. I looked into the green plug today with a bit more detail and noticed that the plug was not sitting all the way in.. after messing around with it for a few minutes I noticed there was a small tab keeping it from clicking in.. I used a small pick and "Click".. I checked my hi beams and they worked just fine. Everything is working how it should and the bambi is also working.
I installed the HID fogs at this point, and all remains to be OK. I also received my VLEDS tag led's and put those in aswell..
I went down the street and took a few pics of what the lights looks like. I can barely notice the difference with the fogs on. Its more of a look thing, than functional one.
Pics are not the greatest, but here goes ..
Old Aug 29, 2011 | 10:33 AM
I like those tag lights! What are they?
Old Aug 29, 2011 | 06:27 PM
MedicF150's Avatar
Vleds
Old Aug 29, 2011 | 06:59 PM
Quite a bit of light there. Good to hear they're working for you.
