F150Online's Retrofit Members
Old Jan 24, 2015 | 09:36 AM
  #166
thelariat02's Avatar
Originally Posted by speedstang
I sent back harness that came with the quick retrofit for the spyder lights. I am using just the harness for HIDs as if the high halogen beam on the spyders isn't there. Hi n low R hid. Hid stays on the whole time n shield flips down for hi beam.
I didnt want the crappy hi beam halogen hooked up. If I could go back i wouldve retrofitted my factor lights instead of buying the chinese crap. If u got it from TRS tell them u want harness for ur truck for hid's only.
Thank you for posting your experience, I knew you'd be able to help
Old Jan 24, 2015 | 10:58 PM
  #167
speedstang's Avatar
No problem. Hoping to junk these Spyder lights n get my factort heads retro'd this year.
Old Apr 24, 2015 | 07:41 AM
  #168
BigBuckMafia's Avatar
I messaged you. If you don't mind message me back or if you can email me at hunterbinkiewicz@frontier.com
Old Jun 12, 2015 | 03:10 PM
  #169
Any of you guys do them for an f-250 ?
Old Feb 9, 2016 | 03:21 PM
  #170
ak_cowboy's Avatar
Hey guys. Doing a group buy over at the other forum with The Retrofit Source. Need 20 guys to get 25% off kits.
http://www.f150forum.com/f83/theretr...up-buy-330139/
Old Feb 10, 2016 | 01:03 PM
  #171
thenewbreed's Avatar
Anyone have any issues with a 55 WATT system burning their factory socket. I had the Morimoto wire harness with morimoto XB55 watt ballasts and Osram CBI D2S bulbs. I had to downgrade to XB35 WATT Ballasts due to this issue. All products from TRS.
Old Feb 10, 2016 | 05:08 PM
  #172
from what i've heard 55w is ok for short term use 30> minutes. but longer burn times get things too hot
Old Feb 10, 2016 | 05:40 PM
  #173
But being that the factory harness is just a trigger for the relay the wattage shouldn't have anything to do with the burning issue.
Old Feb 10, 2016 | 06:10 PM
  #174
unless its too close to the headlight itself?
Could also be a cheap connector that had loose pins that cause heat to jump tiny gaps?
Old Feb 10, 2016 | 06:11 PM
  #175
Finally went ahead and put together a thread on my super retrofit
https://www.f150online.com/forums/il...ml#post5182755
Old Feb 10, 2016 | 06:50 PM
  #176
Very true. I'm leaning more towards a bad connection some where.
Old Jun 15, 2016 | 06:30 PM
  #177
ctucke55's Avatar
The ones I have built
Just a little sample of what I've done...
Old Jun 15, 2016 | 07:24 PM
  #178
ctucke55's Avatar
Yes I've done a couple sets...
