V-led coupon code thread
Old Jan 23, 2011 | 09:48 PM
DarkShadowSTX's Avatar
No problem. V-leds has the flasher also: http://www.v-leds.com/BlinkerWarning...10389-1-3.html It looks like you could have ordered everything all at once if it was in stock.
Old Jan 24, 2011 | 08:47 AM
johnnyd2723's Avatar
Just bought the lights. Flasher's still out of stock but Advanced has them.
Thanks again
Old Jan 26, 2011 | 09:32 PM
Become a fan on Facebook and save!! http://www.facebook.com/VLEDS?v=app_6009294086
I need to be getting commission for everything I've done for this company.
Old Jan 27, 2011 | 03:56 AM
legorreta's Avatar
Originally Posted by DarkShadowSTX
^^ Leds in my heads? Of couse I do, it's called led backlighting. I also have these for the front turn signals: http://www.v-leds.com/Exterior-LED/Turn-Signal-LED/White-LED/TYPE-2-DUAL-COLOR-CHANGING-p7114832.html As far as the reverse lights, get a set of $19 Walmart driving lights and mount them to your trailer hitch, if you have one.
Thats pretty wicked, I like that setup
Old Jan 30, 2011 | 02:54 PM
New code is PUAOJ4 for 15% off.
Old Feb 14, 2011 | 09:43 PM
New code
I just found one, it took some digging on Facebook but here you go:
15% off F754XK
Old Feb 16, 2011 | 01:48 PM
Raptor05121's Avatar
New code
15% off F754XK
Thanks, I just ordered my switchbacks
Old Feb 16, 2011 | 01:55 PM
NP, that's what this thread is for.
Old Feb 16, 2011 | 01:57 PM
Old Feb 22, 2011 | 06:05 PM
Tarpon-Screw's Avatar
For the turn signal bulbs are they plug and play?
Old Feb 22, 2011 | 06:07 PM
Yes, 3157
Old Feb 23, 2011 | 09:00 PM
I don't need a reistor or anything ? Sorry just want to make sure
Old Feb 24, 2011 | 02:01 AM
Yes, for every turn signal you replace, you will have to add a resistor. Or, the easier and cheaper way is to get a Tridon EP27 LED flasher relay from AdvancedAuto for ~$11 and that takes care of it too.
Old Feb 24, 2011 | 06:26 AM
X2 on the flasher, fixes everything now and if you ever get the other set of turns in leds also.
Old Feb 24, 2011 | 10:01 AM
Where does that relay go?
