Thanx Raptor....by finess, you mean a lil' "influence" to make it fit or does it require housing altering? Im assuming just having to twist and turn till it seats correctly
If you compare the locking tabs on the two bulbs very carefully, you'll see that one tab is just a bit bigger. You can "finesse / influence" the bulb by moving it around a bit as you twist and it will eventually go it. Or, if you're adventurous, you can take a small pair of diagonal cutters and trim the tab - which I've done successfully several times.
And as I've said before, this is the only safe modification I've used and recommended - many times. It will also give you a bigger increase in usable light (that doesn't **** off oncoming drivers) than anything else out there. Too bad it only works with the rectangular fogs on the newer trucks and the 1997 - 1998 fogs.
I just installed the H13 Silverstar Ultra zXe's and the 9005 Silverstar Ultra zXe's this past weekend. A big difference over the stock, but the stockers were also 9 years old too.
