HVAC Cold Air at Idle
Old Jan 17, 2014 | 05:43 PM
Armyboy61's Avatar
I have a 2011 with a 5.0 and I'm having issues with cold air blowing when the heat is on. I only have this problem when the vehicle is idling. As soon as I start driving it blows warm air, but even coming to a stop at a red light it starts blowing cold air again. If I rev the engine up though, it'll blow warm. Do I have a bad thermostat? I don't much trust my local Ford dealer so I wanted someone else's thoughts. Thanks in advance!
Old Jan 17, 2014 | 06:17 PM
Did you check the coolant level yet?
Old Jan 17, 2014 | 07:19 PM
projectSHO89's Avatar
No, it's not your thermostat.
Check coolant as already suggested, then check water pump.
Old Jan 18, 2014 | 01:24 PM
Armyboy61's Avatar
Thanks guys, that was indeed my problem. Glad it was something minor.
Old Jan 18, 2014 | 07:57 PM
Low coolant? Now you need to figure out where the coolant is going! This may not be a minor issue.
Old Jan 20, 2014 | 10:05 AM
Armyboy61's Avatar
Yeah, I know I lost some when I installed my CAI, but not that much. I'm always checking my driveway for leaks, and have never seen any. Where else could I check to see where it's going?
Old Jan 20, 2014 | 12:37 PM
It could be consuming coolant internally. Or even heater core leaking inside the truck. Or a reservoir cap that doesn't hold pressure can cause coolant loss
Old Jan 20, 2014 | 12:44 PM
Armyboy61's Avatar
I've had past trucks with heater core issues where they leak on the passenger side floor board. That's not the case here, and I do have pressure on the reservoir cap (I can hear it). Do I need to be concerned if it's consuming coolant internally?
Old Jan 20, 2014 | 03:07 PM
Absolutely! You could have a blown head gasket or a cracked head.
Fill the coolant to the FULL line and keep a good eye on it.
Old Jan 20, 2014 | 03:12 PM
Armyboy61's Avatar
I will keep an eye on it. I appreciate everyone's help!
