No Temp. Control
Old Apr 21, 2000 | 10:00 AM
Bob Stout's Avatar
Angry No Temp. Control
'97 F-150 Lariat, 4.6L
Does the temperature control work with
vacuum, electric or a combination of the two maybe? I,d appreciate any info. No control now. Did have hot or cold, but nothing now.
Don't want to have to pay the Ford dealer a couple hundred if it's something I can fix myself. Thanks!
Old Apr 26, 2000 | 01:06 AM
Granpa's Avatar
Post
I didn't notice your post before, its now 5 days old, don't know if you need the info any more.
But if you do, all functions are vacuum operated, EXCEPT the Blend door Hot through Cold control. It is electric. The temp control **** turns a potentiometer, 3 wires go from it to the Blend Door Actuator. The actuator also has a ground, and a +12 volt coming through fuse #5 , a 15 amp fuse, in the dash fuses.
Old Apr 28, 2000 | 11:10 PM
Bob Stout's Avatar
Post
Thanks for the reply Grandpa, I'm going to check it out tomorrow. I'll let you know what I find.
Old Apr 29, 2000 | 08:06 PM
Bob Stout's Avatar
Post
The blend door actuator is bad! Thanks
again for the help Granpa.
Old Jan 9, 2002 | 12:17 AM
whatdayathink's Avatar
Does anyone happen to have any pictures or instructions on how to get to the blend door actuator. I am having trouble with my heat being intermittent. If I turn the temp up and down a few times or turn the system to off and then on, sometimes I can make it work.
Also - what is the procedure for testing the actuator to make sure it is not the panel control.
Thanks!
97 F-150
Old Jan 10, 2002 | 11:23 PM
Corpsie's Avatar
To test the blend door, you can try to run a wire down the pass-side center duct and see if you feel the blend door hit it as you move the dial back and forth.
I think the blend door actuator is located on the firewall side of the HVAC. It's a medium thin white box (could be black) held on by 2 screws.
I'll ask my contacts about it's exact location and try to get back with you asap
Old Jan 10, 2002 | 11:41 PM
Thanks - that would be great. I actually put my head down by the floor on the passenger side and could hear the door operate. When I went to cold it sounded ok, but when I turned it to hot it sounded like it has having some type of problem and it did not sound "quite right".
I would like to replace this myself and feel technically competent to do it, I just need to figure out where it is so I am not fishing all day...
Thanks!
Old Jan 11, 2002 | 07:06 PM
Corpsie's Avatar
Exclamation
"The blend door actuator is located in the center of the car on the bottom of the HVAC case. It is just above the hump in the floor pan."
IIRC, you can pull out the pretty-panel (the big plastic thing in front of the floor ducts), then you need to pull out the accelerometer (2 bolts, box on the floor) and you should be able to access the actuator (tight squeeze)
