Vent and floor heat = ac on? Help!
Old Mar 12, 2009 | 12:41 PM
20Screw01's Avatar
So when I turn my trucks heat to vent/defrost or vent/floor it will turn the ac compressor on? But if I leave it on just floor or vent it is fine. It seems like when it does two at the same time it is clicking on the compressor?
Any idea's ???
Thanks Dave!
Old Mar 12, 2009 | 03:38 PM
sfam198's Avatar
not sure about the vent/floor setting, but anytime the defroster is on, the ac will run. that's by design. whether you have just the defroster on or the floor/defrost setting, the ac will run.
edit: just remembered i saw something in my owner's manual when i last read it that the ac will come on with the defroster when the ambient temp is above 35 degrees. i could be wrong about that, but i believe that's what i read.
Old Mar 12, 2009 | 04:11 PM
20Screw01's Avatar
Any reason why? I had a 99 exp and 04 navigator and it never did this ??
Old Mar 12, 2009 | 05:46 PM
sfam198's Avatar
the defroster uses the a/c to dry the air coming out of the vents. if you are using the defroster to de-fog your windshield for example, blowing out air with any moisture in it will just make the fog worse.
Old Mar 12, 2009 | 08:17 PM
20Screw01's Avatar
Got it....It does this also when the vent and floor is on so anything I could check to see why its doing this?
Old Mar 12, 2009 | 10:59 PM
chiefFX4's Avatar
thats just the way these air conditioners are designed.
i think its only the panel setting that doesnt turn the compressor on. there is a wire you can add a switch to that will stop this happening. i wanna say its the purple one coming out of the a/c controls but dont quote me on that.
Old Mar 12, 2009 | 11:09 PM
projectSHO89's Avatar
Fords are typically designed to operate the compressor in all modes except OFF, FLOOR, and VENT.
See your owner's manual for details.
Steve
Old Mar 12, 2009 | 11:19 PM
20Screw01's Avatar
Does it stay on all the time when you turn it to vent/floor or does the compressor cycle on and off?
Old Mar 13, 2009 | 07:28 AM
I guess is should have used the word enabled instead of operate.
Actual operation, once enabled, is still controlled by the cycling switch, relay, and the PCM (depending on year) based on the usual variables.
Steve
