Formula for a 12 second HD-F150?
Old Aug 13, 2002 | 12:07 AM
  #46
ken800's Avatar
what do you suspect those bars weighed for the pair? 50lbs? 75 lbs?
Old Aug 13, 2002 | 12:46 AM
  #47
cobrasvt1's Avatar
they were real light prob 20lbs each if that
Old Aug 13, 2002 | 12:53 PM
  #48
Harley#356's Avatar
uh-oh, there goes ken looking for another way to loose some weight off the truck
you should take off that big heavy metal piece on top of the engine. All it does is make that loud whining noise
Old Aug 13, 2002 | 01:28 PM
  #49
Former Sponsor
The "formula" for a 12-second Harley model varies a bit from the Lightning, but in realistic terms primarily it's an issue of needing more power to get the same kind of ET's, obviously, due to the increased weight of the '02 Harley. The '02 Harleys make less power stock compared to the Lightning obviously, and not only do they make less boost, but they also have a more restrictive exhaust setup as well as another 500-600 lbs. of weight. Where many Lightnings can crack into the high 12's with a Superchip, intake kit & a set of slicks, the Harley needs significantly more to do this.
Virtually all the same Lightning parts work on the HD, the upper pulleys gain more boost on the '02 HD model of course due to it's larger blower pulley stock.
We have a lot of these trucks running around with our packages on them, using 4-6 lb. lower pulleys, and some using that in addition to a blower (upper) pulley, as well as throttle bodies, electric fans, intakes, long-tube headers, high-flo cats, proper tuning & attention paid to the suspension when needed.
These HD's generally tend to run about 14.4-14.7 in heat, 90 degree temps. So the issue here is to drop about 1.4 - 1.7 seconds off their ET's to be able to break into the 12's, and in Summer heat it takes signifcantly more modification to get into the 12's compared to what's need to do that in 50 degree Fall temps, obviously. That's a real key word here, "heat," as these computer controlled Lightning motors are extremely sensitive to heat.
Anyone wanting to improve the performance of their supercharged Harley can give us a call & we'll be happy to map out a plan of mods that will get the performance of your supercharged Harley where you want it to be.
Old Aug 13, 2002 | 01:36 PM
  #50
tazhalo's Avatar
on the 02 to put the air force one on i just take off the stock tube and stock box and plug the map sensor back into the throttle body?
Old Aug 14, 2002 | 08:05 PM
  #51
harleybull's Avatar
i ran my 02hd a couple of sundays ago it ran 13.75 at 99.94
w/a 2.01 60 ft.
weather conditions were about 90 degrees and lot of humidity
my truck made 420rwhp anf 525 rwtq the day before .
i had only about 20-30 minutes of cooldown.
my mods are:4lb lower,2lb lightning upper,custom tuned
diablo chip and k&n filter off a cobra.
i hope to put the electric fan and w/pump on next weekend and
maybe a trans mod.
to the best of my knowledge a long cooldown is worth about
2-3 tenths and 2-3 mph.
by the way i weighed my truck also it was 5200lbs with no driver.
Old Aug 20, 2002 | 07:16 PM
  #52
FastHarley's Avatar
Electric fan install
Have you done the electric fan install yet - and did you encounter any problems (electrical) with it?
Old Aug 21, 2002 | 11:49 PM
  #53
JohnnyLightning's Avatar
12 sec. HD? We at JLP hope to post some (sub) 12 sec. runs with the HD soon. we @ JLP have decided to purchase a HD For more research. we'll post the results when we have them. 1 big help will come from the KB supercharger The rest will be up to me. JL
Old Aug 22, 2002 | 12:53 PM
  #54
slingshot's Avatar
Johnny--That's great news! I have a feeling a lot more HD-specific parts will be available soon... BTW--You're gonna love the truck.
