Screw Dyno Numbers lets see some times...
Old Jun 12, 2002 | 09:15 PM
GT-40 GTS's Avatar
Wink Screw Dyno Numbers lets see some times...
Am I the only one who goes to the track ?
Lets not start looking like Ls1.com.
Post some times with temp, 60 ft and so on.
My Best so far is(1/8mile):
9.06 @ 78.5
60ft 2.10
Temp in the 80's
Allt. corrected for that day to be like 2000 ft.
Old Jun 13, 2002 | 10:08 PM
harleybull's Avatar
my 02 went 14.99 at 93 w/a 2.29 60ft
the truck had 75 miles on it and it was
85 degrees w/100% humidity and no
cool down right of the hwy.i have not been
back since!
Old Jun 16, 2002 | 02:09 AM
drop-top's Avatar
Maiden Voyage, bone stock except k&n...
60' 2.32
1/8 9.79
mph 73.51
Its a start, but not for long!!!
Old Jun 16, 2002 | 10:28 AM
Mystery Fan's Avatar
Registered User
6/7/02
60' 2.24
1/8 9.704 @ 75.24
1/4 14.98 @ 92.92
85 degrees 54% humidity
with fiberglass tonneau and no weight removed.
Only mod I have is JLP dual ram air kit.
Old Jun 16, 2002 | 12:26 PM
cobrasvt1's Avatar
quarter mile times
in response to your times i have a chip puley ram air and throtle body and have gone a best of 13.3 at 102 with a 1.96 60 ft time it was about 60 to 65 degrees outside when i ran i plan on getting in the 12.s some how on street tires need to fig a few things out first
Old Jun 16, 2002 | 02:05 PM
outnumbered's Avatar
Old Jun 17, 2002 | 09:31 PM
cobrasvt1's Avatar
1/4 mile
i went to the track again today and my best run of the day was 13.218 at 104.19 mph
60foot 1.953
330 5.545
1/8 8.492
my highest mph of the day was 104.79 and it was well over 80 and humid today does any one else run there trucks
Old Jun 17, 2002 | 09:45 PM
Cobra, What size lower pulley do you have? Do you know how much boost you are making?
Old Jun 17, 2002 | 11:26 PM
cobrasvt1's Avatar
i think i have 6 or 7 lbs over stock i will be putting a gage soon
Old Jun 18, 2002 | 10:55 PM
croosr's Avatar
Fuel??
cobrasvt1 - Thanks for the info. Are you running 93 octane fuel? Or race fuel?
My truck seems like it could use more stall on the torque converter during launch. What's your opinion on this with the bigger pulley setup? What RPM are you launching at? Is traction an issue? Thanks.
Old Jun 19, 2002 | 12:15 PM
cobrasvt1's Avatar
traction
when u do the work u don't want to have a higher stall unless u are runing slicks , i run 93 or 94 octane and street tires and launch at like 1100 and roll into the throttle traction is a bit tricky at times if u leave 100 rpms to much the thing spins like crazy for instance on the same day i wnet 13.2 with a 1.9 60ft i also went 13.6 at 104.72 with a 2.36 60 ft once the tires spin it kills the run if u have any questions email me at cobrasvt1@AOL.COM ILL BE GOIN TO THE TRACK TONIGHT TO SEE IF I CAN GO FASTER IF U WANT TAKE OUT THE SPARE , THE BED MATT AND THE BED EXTENDER, I RUN WITH THE SPARE AND MATT IN BUT I TAKE OUT THE BED EXTENDER , ITS HARDER FOR ME TO HOOK WHEN I TAKE THE MATT OUT BELIEVE IT OR NOT THAT THING IS HEAVY
Old Jun 20, 2002 | 12:43 AM
croosr's Avatar
Trade Offs
cobrasvt1 - Yeah, I sort of figured that with more boost the TC stall issue might be a trade off with traction. That's interesting about the mat / weight in the bed. Less weight makes for better acceleration, BUT less traction during launch.
With your estimated ~6 - 7 psi boost increase over stock, you must be getting close the limits of pump gas. I was able to run 16psi boost on a turbo vehicle with 93 octane fuel, but that was on the edge of activating the knock sensor. Does the HD motor have a detonation sensor?
Thanks for you info. Good luck getting into the 12's.
Old Jun 20, 2002 | 01:27 AM
cobrasvt1's Avatar
theres no knock sensor in the hd but as long as u don't run to much timing u should be alright with ore boost
