Pretty Important, check your dipstick!
Old Jan 6, 2003 | 02:00 AM
Factory_Tech's Avatar
It's an assembly plant issue, so for the Lightnings it's only at Ontario, not KCAP where the HDs are built, but check out this forum.
https://www.f150online.com/forums/sh...hreadid=101870
If you have a 4R100, it get's MERCON, not MERCON V, even if the dipstick says otherwise. Just thought I'd post a heads up on this.
MERCON V will destroy your transmission if you have a 4R100, this is pretty important.
G
Old Jan 6, 2003 | 12:08 PM
4WL HOGG's Avatar
Maybe this thread should be stuck to the start of this forum. Sounds pretty important.
Old Jan 7, 2003 | 08:41 AM
flyarmy's Avatar
Yes, I went thru a nut roll with the dealer when I installed the valve body this summer. The Owners Manual clearly says MERCON ONLY in the 4R100 and MERCON V in the other. When I went to buy the fluid, they said they've only heard of MERCON V going in F150s. They had confused looks on their faces when I said it was a HD with 4R100 Tranny, so they said check the dip stick, but apparently some trucks are getting the same dip stick as a regular f150 from the factory. They called a rep at SVT who said plain and simple 'MERCON', as Factory_Tech said.
Old Jan 7, 2003 | 11:26 AM
Fepony's Avatar
Talking mercon
My dipstick says Mercon. Must be the right one.
