Warning - 2003 Lightning Has Wrong Trans Dipstick
Old Jan 3, 2003 | 05:03 PM
superfords's Avatar
2003 Lightning uses Mercon V
I was finally getting around to doing a PDI (pre delivery inspection) on my new truck today and noticed that they are now calling for Mercon V fluid in the tranny.
just thought I'd mention it.
it is a little low, glad I did top it with Mercon III
later,
chris
edit: glad I didn't top it with Mercon III that is
Old Jan 3, 2003 | 05:12 PM
RTKILLA's Avatar
Re: 2003 Lightning uses Mercon V
later,
chris
and its still a 4R100 tranny?
Whats the differene then, greg should know.
P.S. I hope you mean didn't, right?
Old Jan 3, 2003 | 05:13 PM
soap's Avatar
Re: Re: 2003 Lightning uses Mercon V
Same thing I was thinking.
--Joe
Old Jan 3, 2003 | 05:21 PM
superfords's Avatar
oops, yes of course, typo.
I meant glad I DID NOT top it off with regular mercon III
and yes, it's still a 4R100
later,
chris
Old Jan 3, 2003 | 05:23 PM
cpeapea's Avatar
hmm im curious myself, what is the difference? isnt it all just hydraulic fluid?
Old Jan 3, 2003 | 05:33 PM
superfords's Avatar
Mercon V is synthetic or "semi" synthetic. other than that, I have no idea.
BTW, so far I have added TWO QUARTS of tranny fluid and it still hasn't shown up on the dipstick yet. NICE GOING FORD!
Old Jan 3, 2003 | 06:09 PM
DennisWeise's Avatar
Yep, starting in '97 Ford starting using Dexron/Mercon V in some vehicles and will eventually move to the semi-synthetic completely. I guess their tranny inventory is about at that point.
L Speed
Old Jan 3, 2003 | 06:28 PM
superfords's Avatar
Final count, the damn tranny was 3.5 quarts LOW!!!
it took 3 quarts just to get it on the stick, and another 1/2 to get it up to the HOT FULL range.
SWEET!
Oh well, hopefully I didn't hurt it driving it for the past few days.
The funny thing is that it NEVER slipped or didn't engage properly or otherwise exhibit any tranny symptoms
at least the washer fluid was full
later,
chris
Old Jan 3, 2003 | 06:38 PM
Rob_02Lightning's Avatar
Nothing surprises me anymore with Ford after 5 years of defective heads and front ends that clunk and shift when you turn the wheel.
Old Jan 3, 2003 | 06:52 PM
SVT_KY's Avatar
SWEET!
later,
chris
Check to make sure you have the correct dipstick, Chris !!! <grin>
Old Jan 3, 2003 | 07:38 PM
superfords's Avatar
LOL,
At first I thought you meant that maybe I was checking the power steering fluid or something! But then after I thought about it, it would almost make sense if it was the wrong dipstick! Labeled for wrong fluid and reading incorrect level. THAT would be my luck!
but I kinda don't think thats the problem.
later,
chris
P.S. I have clean nails for a mechanic huh...
Old Jan 3, 2003 | 07:55 PM
03LightninRocks's Avatar
Time for a newby question. When Mercon V is called for, I am assumimg regular Mercon is not advised???
How many L owners are useing a straight synthetic fluid and what is best as a replacement for Mercon V???
Thanks,
Rocks
Old Jan 3, 2003 | 08:07 PM
superfords's Avatar
My first answer to this was going to be that I think the clutch material may be different to work with the Mercon V fluid.
maybe somebody with more up to date transmission knowledge will answer this, but here is something that keeps running around in the back of my brain:
I remember a time when Ford had us draining Mercon III out of crown vics (AODE/4R70W) and replacing it with Mercon V to fix an OD or torque converter shudder?
Supposedly the two fluids are not compatible although I've never seen that written on either of the containers. I'd like to know some more info on this topic myself.
later,
chris
Old Jan 3, 2003 | 09:00 PM
MRBBQMAN's Avatar
http://www.nloc.info/forum/showthrea...threadid=33298
Old Jan 3, 2003 | 10:30 PM
B4THNDR's Avatar
Sounds kinda funny that the tranny shifted okay being three and a half quarts low. I would check my svy owners manual and see what it says. Sounds like you could have the wrong dipstick!!!!!!!!
