Old Jan 28, 2009 | 02:01 PM
  #12751
Jditta's Avatar
More than likely, I just know thats a sure fire way I cant switch into 4wd and ruin my gears due to Im only regearing the rear axle right now.
Old Jan 28, 2009 | 02:07 PM
  #12752
Tumba's Avatar
Don't worry, the fluid won't run out. There is a seale in the transfer case.
All you have to do is take the U joint loose, then slide the shaft out.
I hope that helps you.
Old Jan 28, 2009 | 02:08 PM
  #12753
Jditta's Avatar
I'm assuming its just a few bolts? I havent ever really gotten under there and looked.
Old Jan 28, 2009 | 02:19 PM
  #12754
So, it's different from the yolk going into a two wheel differential? When you disconnect the u-joint, there is a sline left that will fall out if you don't remove it, and when you remove it, the grease runs out past the seal. I've never looked at a 4 wheel drive so, I guess the spline is bolted in with a plate?
Old Jan 28, 2009 | 02:21 PM
  #12755
Jditta's Avatar
Since its 4wd I guess it is different. I would assume the rear driveshaft would be different from the front.
Old Jan 28, 2009 | 02:24 PM
  #12756
I figured different but similar as they both come out of transmissions or transfer cases that contain lubricant. But, I've never looked at one. It may be all external driveline with a plate holding the yolk to the transfer case.
Old Jan 28, 2009 | 02:26 PM
  #12757
Tumba's Avatar
You just take it loose at the U joint, and leave the yoke in place.
You don't have to take the yoke out.
The U joint just has the four nuts holding it in place.
Old Jan 28, 2009 | 02:27 PM
  #12758
Jditta's Avatar
Thats what I thought, appreciate it Tum.
Where in Lower Ark you at, wondering how close you are to me??
Old Jan 28, 2009 | 02:32 PM
  #12759
So, the yolk will not pull out like on a two wheel drive? It's bolted in?
Old Jan 28, 2009 | 02:34 PM
  #12760
Jditta's Avatar
Pretty much.
Old Jan 28, 2009 | 03:12 PM
  #12761
Tumba's Avatar
I had to step away for a minute.
I'm in Camden.
Old Jan 28, 2009 | 03:13 PM
  #12762
Tumba's Avatar
You just slide thet yoke out, There is a seale there behind it.
Old Jan 28, 2009 | 03:27 PM
  #12763
Tumba's Avatar
I think I need to clarify that. You Slide the yoke out of the transfer case, there is a seal there. The differential end is where you just unbolt the U Joint.
Old Jan 28, 2009 | 04:07 PM
  #12764
easiest way to disable just pull the trim off of the radio trim and unplug the connector on the back side of the switch.
However you should get better gas mileage if you take the shaft out, less rotating mass, including the differential, and axle shafts
Old Jan 28, 2009 | 04:40 PM
  #12765
Zaairman's Avatar
That's what hubs are for... Or is his truck stuck in 4x4?
